Question about IBM ThinPad R51 (2887EXU) PC Notebook
I DON'T HAVE THE CD ROM DRIVER - IBM ThinPad R51 (2887EXU) PC Notebook
    Brigadier General:
  • 8,909 Answers
If you need to install drivers.
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps
Posted on Mar 25, 2011
CD/DVD driver not working
A few solutions:
1. Have you tried to clean your cd/dvd lens? Probably your lens is getting weak.
2. For advance user: Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- Look for DVD/CD-ROM drives and delete the subkey.
- Restart your machine.
3. Let Microsoft FixIt help you:
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
Worst case - Get a new CD/DVD-ROM for the replacement.
Don't forget to thumb up! ;) Good luck!
Feb 25, 2012 | Lenovo 3000 Y410 Laptop
My printer does not appear in my computer
Hi
May you remove or uninstall by mistake that's way is not showing now don't install again to follow the mention below instruction.
1) Plug on you USB cable to PC and power on the printer.
2) Put the Lexmark printer software installation CD in you computer CD-Rom.
3) Open the CD-Rom, and duble click the setup exe.
4) The setup will take few minute to install the driver.
5) After installing the driver reboot your computer. and start to printing
Cheer
Aug 03, 2011 | Lexmark X4650 InkJet Printer
I don't have an asus cd S520/a5 driver
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
http://download.cnet.com/microsoft-cd-rom-changer/3000-2100_4-10005083.html
Jul 23, 2011 | ASUS CD-S520/A5 Internal 52x CD-ROM Drive
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Drivers for sony cdrw dvd crs8435e missing
try to find the driver in the cartoon of your cd-rw/dvd-rom, or you may visit any sony service center in your area they have a driver in there. thanks
Jun 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I have a reconditionned DELL Precision M3400 laptop that was factory reset when I bought it. I have had to turn on all the hard drives etc. but I am having trouble getting the internal modem to turn on. It...
Usually the recondition, or refurbished product from Dell have been retested to ensure they meet all original factory specifications. I don't understand why your modem and cd rom drive don't work. How long had you purchased it? When you said you can't get internal modem to turn on, you meant it not working?
There are only two things could happen to each of them (modem and cd rom drive) For Modem: please check it through device manager, and modem to see if it has red x or yellow question mark, or says unknown device, if you do have one of these, you need to install correct driver. Please check your Dell service tag number (it is on white sticker on back of laptop), and go to dell.com, support, and select driver and downloads, key in your service tag number, and download the modem driver to install. If it still doesn't work, then the physical internal modem is the faulty one. For your CD rom drive, it should work with just standard driver preloaded by the OS, you don't need to install driver for. It is either dirty, needs to be cleaned by the CD room cleaner disc, or it is bad. You can try to reseat by trying to take whole thing out and insert it back in. If you have Dell diagnostic cd (usually comes with your laptop when ordered) to run hardware diagnostic to find out the faulty one.
This is the common issue with refurbished laptops (most common issue is with keyboard). When buying refurbished one, you have more chances to have some part issues. I suggest to reinstall modem driver to see if it works, and try to clean cd rom driver and reseat it, and hope for the best. Let me know the status Thanks
Jun 16, 2011 | Dell Computers & Internet
DVD/CD-ROM > Does not
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd is getting enough power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps don
Mar 12, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My cd rom is not reading any disc and i keep hearing a clicking sound.
Go to
1-my computer
2-then properties
3-then device manager
4-then look for your cd-rom
5-uninstall the driver (only if you have the cd-rom installation program from the manuf.) and restart your PC
If you don,t then find any conflicts in the device manager "like a yellow symbol" and if you find any try to "update driver".
Keep posting!
Feb 22, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Usb rec. comes up yellow,in device manager
The device driver is needed, right click on the yellow and go to properties, then select update driver. Install the cd rom that came with the device in your computer cd rom drive. If the driver cannot be installed, compatability issue or you just don`t have it, then what you would have to do is try the device web site for an updated driver for your operating system, if you don`t know the maker of the device then your only chance is to do windows update, do all of them and hope windows can find a compatible driver for it. If you are running windows 7 32 bit you might be in luck, if you have 64 bit version, you might be out of luck for now, but keep trying.
Dec 18, 2009 | Logitech Inc MX610 Laser Cordless Mouse...
IBM ThinPad R51 (2887EXU) PC Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
