Question about Tappan TGF320 Gas Kitchen Range
Unlock my Tappan Gas Over Door?
On the oven screen it has F3 and beeping and I have been pushing clear and the oven door will not unlock. Can you help me.
Wilford
  • vomvo Aug 20, 2008
    door wont unlock & the display says F3. I have pushed every button. Its been unplugged for days . Still wont work
    New Friend:
My tappan over has AF 90 code what do I do to make it unlock
Posted on Jan 27, 2016
  • 794 Answers
Hi wewada,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Nothing Works Shows F3 Error
the F3 error code is an oven temperature sensor fault. The sensor is a small probe that sticks out of the back of the oven wall. They do go bad and can be easily replaced. If I had your EXACT model number (found along the inside of the oven door or lower drawer) you can replace it.hope this helps
Jan 26, 2009 | Kenmore 46123 Stainless Steel Electric...
Tappan gas oven dooor won't unlock
We were able to solve the problem by accident. As I think I mentioned the door must of locked when we were cleaning the control panel. Anyway the door locked and the burners would not ignite.The door was open so you were not able to shut it to try and clear it. I searched the owners manual, there were no solutions as to how to reset the Range. I even checked the manufacture's web site. I got down to inspect the door and ran my hand along the inside edge of the oven and there was a button on a spring. I pushed on it and there was a hum and the latch opened and the Range must have reset. It's working perfect now.
Dec 07, 2008 | Tappan TGF320 Gas Kitchen Range
F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Jul 15, 2008 | Ovens
Tappan Millenia Range
Hi ChrisNess,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. If wiring is ok, replace the oven temperature sensor (RTD)
Hope this helps.
Jun 24, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Jun 10, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Door Lock Light Flashing
If you live in Huntington Beach, CA and need appliance repair service call us at (714) 698 88 73 or visit our website Appliance Repair Huntington Beach CA 714 698 88 73
Aug 30, 2017 | Tappan TGF320 Gas Kitchen Range
Fault code F3, then F2
Well here's the details about those codes:
F2 :-
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
F3:-
Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
Tappan tgf355 oven door won't unlock and has code f3
open the back and manually spin the motor for the latch arm it may need to be replaced
Oct 31, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
208 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
