I'm facing the same issue on my Panasonic PT-47WXC43 TV. I was quoted $400 to repair, and I think not. LOL At any rate, I am an old Air Force electronics tech, former depo level monitor repair tech turned Database Geek..and this doesn't scare me too much to give it a shot and save the cash. Only thing is, I've never seen anyone work on one of these and am not sure which capacitors might zap me and so forth. I know we had one specific one in the color board of the 15' gateway monitors that would hold a charge and zap the **** out of you if you weren't paying attention....did you run in to anything like that? Can you think of anything else I should be on the lookout for? I'm good with a soldering iron, so I'm not worried about the actual ICU replacement.
Thanks for any help..and especially for your complete guide to replacing these you posted. That was awesome!
Cheri
Comments:
Aug 03, 2008
- Thanks for all of the help! I'll let you know how it goes. I've ordered the chips, and should have them in a few days. The only difference I can see in the description of yours is that there is only 1 screw I can see that holds the chips on to the heat sinks. It has like a clip keeping them in place and a screw holding the clip...so, I'll see how that pans out. :o)
There are essentially 2 boards in this TV. One has all of the high voltage stuff on it and connects to the tubes. The other has stuff like these convergence ICs and other electronics. While the boards are electrically connected, none of the high voltage lines run to the convergence board, so you should be ok.
To be safe, I left the TV off and unplugged for about a day before I started the replacement, but as you read in my saga, I didn't get it right the first time. By then I was pretty comfortable with the electronics and didn't worry about the high voltage lines. But take the obvious precautions like not touching things you shouldn't, and if you feel it necessary, maybe wear gloves.
The only other thing I can say to be careful of, is that the washers on the screws holding the heat syncs to the ICs will not come off, so be prepared to replace them after cutting them off. Also the heat syncs get really ot in operation, so don't touch it after it's been on for a while.
Let me know if you run into any trouble. Set is still working fine a month+ after fix now.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
my panasonic projection tv stopped working. the red light stays lit when turned on and it makes that...
(More)
my panasonic projection tv stopped working. the red light stays lit when turned on and it makes that high pitched sound as if its working but no picture. went from working fine to only one vertical line working then to nothing. took it apart but too much to mess around with especially when you dont know what to look for. please help
already replaced the convergence chip and resistors in our panasonic rear projection tv but now...
(More)
already replaced the convergence chip and resistors in our panasonic rear projection tv but now it's burning up the resistors when we turn the tv on.
I have two issues with the picture on my screen. 1)There is a red tint on the screen. I've tried...
(More)
I have two issues with the picture on my screen. 1)There is a red tint on the screen. I've tried adjusting all of the color options, but it remains. 2)My tv doesn't show the color green. If I'm watching a football game, the field appears to be a grayish, reddish, brownish type of color. Extremely dull. Some images, such as a jersey seem to be green, but I may just be fooling myself into thinking it's green. Ive also noticed this on food commercials. Lettuce looks brown, instead of green. Are these two issues related? Is it an easy fix, or will I need to take it in?
I have a panasonic tv PT 4743 that turns on and than sounds like it is shutting off and than I get...
(More)
I have a panasonic tv PT 4743 that turns on and than sounds like it is shutting off and than I get three blinking red lights in the led. Can this be easy to fix? Thanks
