Question about Pinnacle Studio Version 9 for PC
In pinacle studio 9 plus I go to import DVD titles and when i get them into the project there is no sound track with the clip. So when I play them in the preview window there is no sound. Can you please help me??
  • 6 more comments
  • arnieknoblic Mar 28, 2011
    I tried deleting quicktime and studio and did exactly what they suggested but it did not work.
    I still do not get sound when I import dvd titles and even before I add them to the project there is no sound, but if I play them from the destination folder they play with sound there.
  • arnieknoblic Mar 31, 2011
    I don't know exactly how to change the dolby settings in the dvd recorder or if that will even solve the problem. Maybe you could explain it to me.
    I have tried everything suggested and a few of my own and I can't believe that the import DVD feature will not allow me to get both the video and audio tracks to import in to the project screen. That feature is completely useless without the soundtrack.
  • arnieknoblic Apr 03, 2011
    I tried downloading the k-lite codec that was suggested, but that didn't work either. I still don't get a sound track when I get the clip into studio. However if I open it in the destination folder the media player will play it sound and all.
    Unfortunately there are no import settings or preferences to change so that last solution was no good either.
  • arnieknoblic Apr 04, 2011
    i WILL TRY THE PLAYER THAT YOU SUGGESTED BUT i DOUBT THAT IT WILL WORK THE PROBLEM IS NOT THAT I CAN'T PLAY THE CLIP IN ANY PLAYER BUT THAT I CAN'T PLAY IT WITH SOUND IN THE PROJECT IN THE STUDIO ONCE I IMPORT THE DVD TO THE STUDIO FOR EDITING. I WISH I KNEW WHAT WAS CAUSING IT TO IMPORT WITHOUT A SOUNDTRACK. THANKS.
  • arnieknoblic Apr 05, 2011
    Okay I downloaded and tried the VLC player and messed around with it for a couple of hours but like before in the project in the timeline there is no sound track, so I am not able to do any editing. See that is what this is all about is being able to put it into the project so I can edit it. Then once I have it the way I want it I can burn it onto a disk but because there is no sound track hence there will be no audio. The format is mpg or mpeg but I can't figure out why the sound track isn't making it into the project but it does make it to the destination folder. Because of this the import from a DVD feature is worthless cause there is no sound.
    So what you are telling me is that I need to get Pinnacle Studio 12 in order to make this work. And then follow the instructions that you laid out. Or I could just get Studio 15 that would work on my windows 7 computer and do it that way being I have to get a newer version anyway.
  • 4,889 Answers
Pinnacle stuido is known for plug in issues. Its just missing a codec or something. Save it and play it in any regular media player to see if it works. I recommend VLC player.
http://www.videolan.org/vlc/download-windows.html
It should play just fine. If not let me know
Posted on Apr 04, 2011
  • eagle338
    eagle338 Apr 04, 2011
    In that case you will need to check if there are any plug-in packs available. Please let me know the video format and I will locate the codecs for you.
  • eagle338
    eagle338 Apr 05, 2011
    Are you editing in SD or HD? I am asking coz HD editing is really processor hungry and I have seen it cause problems if the machine is not powerful enough to handle it.
  • 2,427 Answers
Check your preffrences, If you have the title set to demux you must turn on automatically import sound, or import the audio track automatically, Simply put the problem is in your preferences and settings. check your import settings and your audio settings. Check the default audio track as well.
Posted on Apr 03, 2011
  • 2 more comments
  • Rishi Roshan Ali Apr 03, 2011
    Pinnacle Studio 9 does not support direct DVD importing!!! I'll EXPLAIN.......However, using DVD Decrypter, you can quickly and easily convert your DVDs to a video format that is compatible.....#
    Insert the DVD into your DVD drive.
    # 2
    Open DVD Decrypter and in the top menu bar select "Mode>IFO."
    # 3
    Go to the "Stream Processing" tab and choose "Enable Stream Processing."
    # 4
    Select the first video in the list and highlight it.
    # 5
    Click the "Decrypt" button in the left bottom corner of the window.
    Importing the Video to Pinnacle Studio 12
    * 1
    Open Pinnacle Studio and click on the "Capture" tab.
    * 2
    Click "File" and choose "Import."
    * 3
    Browse to the .vob file that you created using DVD Decrypter.
    * 4
    Click "Import."
    you need to fix the streams first ... I forgot about that in my initial post, only when the stream is fixed you can import dvd
  • Rishi Roshan Ali Apr 04, 2011
    As i said you cant Import directly from a dvd as the steams for audio arent fixed duringing the burning process. The FEATURE was meant to import from a HARD DRIVE FIXED copy, you can convert your dvd to a fixed stream and 7 to 8 minutes using dvd decrypter and the method i outlined in the above comment. TRY IT you will see it works!
  • Rishi Roshan Ali Apr 05, 2011
    the instructions are from 9 to 15 no need to upgrade your version of the software.. just follow them using your current version. Even in 15 if the streams arent fixed the audio fails as well, so you will still have to fix the streams on dome dvd's. Its not all you will have to do this for, but most of them.
  • 2,574 Answers
Download and install K-lite codec pack full version .This should fix the issue.
Posted on Mar 31, 2011
    Sergeant:
  • 223 Answers
Thank you for using FixYa
There may be an issue with Dolby Digital AC3 sound that version 9 does not work well with, so try converting the sound to MPEG or PCM. You may be able to change it first in your DVD recorder first.
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 28, 2011
  • Dennis Dilley Mar 31, 2011
    If you are not able to change it in the DVD recorder or if it even has that capability, then the only other thing I can think of is to output it to another source, program or app. first, like Windows Media, and then try to convert it as you save it. That would add another whole step, and take time, but sometimes the long way is the only solution. Otherwise your Program simply does not support the format, sorry in advance for the difficulty.
  • 384 Answers
Hi There,
The cause of this problem is a conflict between Apple's quicktime player ver. 7 and an older version of SmartSound software.
You must use QuickTime 6.5.1, Studio 9.4 upgrade requires QuickTime 6.5.1. Simply removing QuickTime 7 doesn't fix it and removing and/or reinstalling Pinnacle 9.3 doesn' fix it.
My recommendation is to uninstall Quicktime and delete all folders associated with it. Next is to uninstall Pinnacle Studio and everything associated with it. Then :
  • Re install Studio8 completely
  • Re install Studio9.3 - this also installs Quicktime 6.5.1
  • Install Studio9.4 upgrade
I hope this helps you out.
Thanks for using Fixya.
Posted on Mar 26, 2011
Video clip won't play in slideshow
change the format of your video clips
Jun 30, 2010 | Ulead VideoStudio 9
I have bought a cannon XH-A1 HDV camera but find i cannot capture scenes using Pinnacle Studio plus v9 could you please advise me on what is required, may be studio 11 plus for windows XP will solve this?
Hi there
Pinnacle Studio Plus V.9 can only be used for editing DV and not HDV however Pinnacle Studio Plus V.11 can be used to edit both DV and HDV.
Please remember to put a good rating on this post.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Cameras
I want free downd load soffwhere pinacle.please Shir !
If you want a free alternative to Pinnacle Studio Plus. Trying OSALT.com or http://alternativeto.net these have all the free versions of software that you could ever need.
Also, I have located the free version of pinnacle studio for you, look at these submissions, you should find one that works for you, they are all free to use depending on your operating system.
http://alternativeto.net/desktop/pinnacle-studio/?license=free
Hope this help,
Jake
Jun 30, 2010 | Pinnacle Studio Plus Version 11
Problem opening Pinnacle Studio Plus 9 Project
Updates and/or patches may need to be reinstalled for Pinnacle Studio Plus 9. Check here: Downloads
Feb 28, 2017 | Pinnacle Studio Plus 9 for PC
Lost audio during edit videoStudeo 10 plus
audio track in ulead video studio 10 plus -attribute volume is set to zero and grayed so i cant activate it.checking it. checking duplicate audio track activates audio by track but mutes again when i play the project-used to work.system dell XPS M1730
May 21, 2009 | Ulead VideoStudio 9
Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Apr 26, 2009 | Sony Sound Forge Audio Studio 9
HP Tochsmart DVD-RW drive not playing cd's /dvd's
The best player is Video Lan Controller (VLC) is plays everything.
You need the RIP command as you have not a data disk but a multimedia disk (.CDA) file.
Jun 13, 2017 | HP Pavilion TX2000Z Tablet PC
Studio 11 want allow me to burn my project to dvd
I suggest to render the project to a video file first avi conversion to isolate the case. Once you have finish import the AVI file in the pinnacle did try to create now the dvd disc so that the rendering process will be fast since that you already have the file not the project.
Jan 05, 2009 | Pinnacle Studio Plus Version 11
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Re: No sound
yup 9 proable dont suprt vista 11 verison will and beter
Jan 05, 2008 | Ulead VideoStudio 9
Pinnacle Studio Version 9 for PC Logo
99 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
