Question about Canon PIXMA MX850 Multifunction Printer
Canon mx850 Error code 6A00 - Canon PIXMA MX850 Multifunction Printer
  • 812 Answers
Hello thank you for using FixYa.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MX850 Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly,where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you will find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
For Further assistance, I am here to help.
Thanks and Keep exploring FixYa
Posted on Mar 25, 2011
SOURCE: My Cannon Mx850 Printer has
I had the same problem after a paper jam. I removed all the paper and still had a same error. I read around the internet and ran into other Canon printers with similar problems. The error is caused by the print clean mechanism getting stuck. The suggested solution for other Canon printers also worked allowing me to fix my printer. First thing I did was turn off my printer. Second is to open the top cover allowing me access to the print cartridge area. With the power off, you can pull the printer cartridge carridge from the right of the printer to the left. Once you do that, look into the area in the right where the print carridge was and you will see two sponges in the bottom of the printer. Behind them to the left is a little mechanism that moves over the to clean them, I gently gave it a pull and it moved a little forward. I closed the printer and turned it back on. Error went away and it's working fine again.
Hope this helps!
Posted on Mar 09, 2009
jonniewalker
  • 1031 Answers
SOURCE: Canon MP830 error code 6A00
The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere.
2) there may some paper stuck somewhere around the printhead and or the purge unit or
3) there is a build up of gooey ink on the purge unit.
, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, plug the unit back in and hopefully it will work fine. hope this helps.dont forget to rate as fixyaa
thanks and Godbless
Posted on Oct 12, 2008
pineworks
  • 4041 Answers
SOURCE: Model Canon MX850. Display error message 6A00.
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
komguy
  • 2306 Answers
SOURCE: Canon iP6700D error 6A00
6A00 is a purge assembly error, thats the cleaning unit on the right where the printhead parks. Look on the right with a flashlight and see if there's paper, or anything that doesn't belong. If the wipers are jammed into the pad assembly, you will need a new purge unit, best changed by a shop.
Posted on Aug 08, 2009
jhaugan
SOURCE: getting error code 6A00-Canon PIXMA MX850 all-in-one printer
With our MX850 I managed to get it working by simply cleaning as much of the of the residue ink from the right hand side as possible. I simply used a tissue but a cloth would be better.
Posted on Dec 17, 2009
What is the Canon MX850 Error Code 5110?
The paper goes in from the front, under the 'paper output' tray.
Feb 14, 2015 | Canon PIXMA Office Equipment & Supplies
Mx850 canon all in one. was working fine then the alarm light came on and screen shows error code 6A00??? have tired moving the ink cartrigde device, unplugged and pluged back in ... checked everywhere...
6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
Dec 31, 2010 | Canon PIXMA MX850 Multifunction Printer
Mx 850 gives error code 6A00 . We have purchased
6A00 means the purge unit is not cycling properly. If the printhead can come out of the right corner, you check there for paper scraps. If it's stuck on the right with this error you will need a shop to take apart and see if you need a new purge assembly. The part cost is only around $20.00
Feb 22, 2010 | Canon PIXMA MX850 Multifunction Printer
Error code 6A00 comes up. Data line and power cord
That error means the purge assembly is not working properly. Could be a scrap of paper stopping it from cycling properly. The purge unit is the cleaning assembly where the printhead parks, it has caps that draw ink from the printhead to clean and a squeegee to wipe off the excess ink. If the printhead comes to the center, unplug printer and check on the right. If nothing there you probably need a shop repair.
Feb 15, 2010 | Canon PIXMA MX850 multifunction InkJet...
Error code 6a00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 14, 2009 | Canon PIXMA MX850 Multifunction Printer
Error 6A00,under warrenty
Hi
All the best
Solution 1:
Solution 2:
Solution 3:
Oct 14, 2009 | Canon PIXMA MX850 Multifunction Printer
I have a new canon MX850 all in one printer. Only had it a month and an error code 6A00 has come up on the LCD screen.
Error code 6A00 indicates purging operation error. Please observe purge unit first, it's located in right inside the printer. Is there broken paper disturb its function?. If there is no another material out there,means purge unit is faulty and you need to bring you printer to nearest service center.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 05, 2009 | Canon PIXMA MX850 multifunction InkJet...
Model Canon MX850. Display error message 6A00. Turnoff and unplugged printer, replugged in and turn on with same result: error message6A00. What to do?
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 01, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MX850 printer. will not print and shows error code 6A00
Hi
Here is the codes
Solution 1:
Solution 2:
Solution 3:
Sep 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon PIXMA MX850 Multifunction Printer Logo
1,883 people viewed this question
old marine
old marine
