Sony KDL40V2000 LCD TV not working. When power is turned on and the TV is in stand-by mode, a 'double-clicking' can be heard approximately every 13 seconds. When the TV is turned on using the remote-control, a fleeting programme image will appear for literally less than a second before the TV returns to standby mode with ensuing double-clicking noise. This step will repeat itself 3 times before the TV returns to a standby mode permanently, the red lcd flashing 9 times consecutively.
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
  • 5 more comments
  • Todd Hill
    Todd Hill Mar 26, 2011
    there is no 500mic cap
  • Norman Skinner
    Norman Skinner Mar 26, 2011
    there very well may not be in this unit, but they do exist. - my point was that you can go above voltage but should stay on rating.
  • Todd Hill
    where is the parts house where i can buy a 500 mic cap? please give me the website and you can replace a 680 mic with a 1000 will work fine
  • Norman Skinner
    Norman Skinner Mar 27, 2011
    google 500 uf electrolytic, there's a ton of places you can buy them, and no you can't replace a 680 with a 1000 unless it's basically only doing ripple filtering. Capacitors have specific values for a reason, and anything frequency sensitive like ...oh...say...the switching mode power supply or inverter board - require the right value capacitor. Do some research before you start slamming the REAL professionals on this site! Thank you.
  • Todd Hill
    Todd Hill Mar 27, 2011
    yes ripple filtering thats what a cap does for pure dc switch mode witch caps? and what is freq sens. are you talking capacitive reactince 2pie f/l
  • Norman Skinner
    switching mode power supplies aren't pure DC, they are pulse width modulated outputs that aren't ripple filtered until the output.
  • Norman Skinner
    http://capacitor.tedss.com/500uF
    Oh lookie here...500uF caps from 10V all the way to 450V - and this is just ONE supplier !
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Turn demo mode off on Sony Bravia TV 40"
Here'show to turn off the demo mode,
Power ON the television
(Use remote Commander)
1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
2. Press the "home" button on the remote.
3. Select "settings"
4. Select "set up"
5. Scroll down to "factory setting" and restore them.
6. When it asks home or shop display select "home".
Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My sony tv automatically goes into stand by mode and we have already changed the power supply as solution given by fixya .com
If the unit is playing normally then goes to stand-by, it could be also caused by the main board and or the ballast boards. If it is caused by the ballast boards, it should give you error code with the red stand-by light blinking 11 or 13 times. If the stand-by light does not blink a code, it is probly the main board.
I hope this helps,
Skyassoc
Dec 08, 2010 | Sony KLV32S400A 32 in. LCD TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
The power indicator is in stand-by mode but the tv no turn on
usely mains power board ( capacitors blown you can tell this they will have raised tops ) and if clicking can be heard this is a sign that fault is on power board
Nov 08, 2009 | Samsung LN32A330 32 in. LCD TV
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony icf-dvd57tv Combination tv is approximately
This is symptom of faulty inverter circuit causing screen is black .Replaced the inverter so it works normal again.
Regards:
VOTIT
Jun 29, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Feb 20, 2009 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
395 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
