What are the specs for the condenser fan blade and motor for a btb824a100a?
2 Suggested Answers
  • 127 Answers
SOURCE: Do you know the blade pitch (or CFM required) for
Fan blade 22 deg pitch, 22in dia 3 blade
Posted on Aug 24, 2011
Testimonial: "Thanks for helping me out!"
Condenser fan motor
It would be easier to get the data from the condenser fan motor than attempt to match AC unit model numbers. If unreadable then remove the fan motor and take to someone to match with the one you have. That is what I do, Thanks Sea Breeze
Make sure you mark your wiring before removal.
Jun 14, 2013 | Intertherm Heating & Cooling
How to replace condenser fan blower wheel and where can i get one ?
Hello, in order to replace the condenser fan you will need to remove the motor aseembly and use a hub puller to remove the fan blade. When removing the fan blade spraynsome wd- 40 on the motor shaft and then attach the hub puller to remove the fan blade. You csn buy the fan blade at any heating and cooling store.
May 07, 2012 | Continental Heating & Cooling
My magic refigerator/freezer condenser fan stops but when I move the fan blade it starts working and the refrigerator get cold again. Is it a bad fan unit or something else?
yes if you can barely touch blade and it stops the fan motor is bad. While replacing conderser fan motor be sure to clean dust from condenser coil.Then as regular maintiance clean coils twice per year.
Aug 12, 2011 | Refrigerators
My air condotioner is blowing out warmair.It blows out cold air forabout 5 minutes then warm again it's a 5050 series
It sounds like the unit is cycling on internal overload. The overload is switch the protects the motor from getting too warm. This would explain your cooling "cycling".
Check the condenser (the outside coil with vertical fins, the back of the unit). Is it clear of any debris? If not clean it using water or compressed air, using care not to bend or damage the fins or electrical wires/components.
Check the condenser fan motor. You can usually see the condenser fan motor through vents in the sheet metal. Check to see the the condenser fan motor runs when cooling is turned on, secondly check to make sure the fan blade is not broken, usually the blades are plastic. If the motor or fan blade is bad, you need a replacement.
Jul 12, 2011 | Goldstar WG5000 Air Conditioner
When the motor starts their is a rattle noise..When I looked in the back I noticed the fan blade had some play in it could that be the problem..
The shaft of the condenser fan motor will have some play in it, meaing if you are looking at it from the side, along the plane of the fan rotation, it will float to and from the motor itself, or left and right as you look at it from the side. You can isolate the noise by unplugging the refrigerator no less than 5 minutes, a minimum of 5 minutes and for at least 5 minutes. Before you plug the appliance back into the outlet, grab and hold onto the condenser fan blade, it will only be for a few seconds, and the motor is not strong enough that the blade will be ripped out of your hands. If you prefer, you can hold the blades in place by holding a screwdriver in between the blades instead. Plug the unit in, and if you still hear this rattle noise, its the compressor, not the fan motor. If you dont hear the noise, remove the screwdriver between the blades, and listen for the refrigerator noise as the fan motor starts up. If it made the noise then check for any obstructions to the fan blades, check that the three screws that secure the motor are tight, if they are loose, the fan will bounce. if they are tight, you probably have a bad condenser fan motor
Nov 09, 2010 | Whirlpool (ET1MTKXKQ) Top Freezer...
Just had the condenser fan motor replaced on my 550 sub zero refrigerator. I forgot to asked the serviceperson the following questions: Does the fan continously stay on and what is the normal sound of...
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Oct 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
I NEED A CONDENSER FAN MOTOR WITH BLADE AND
cna't find your model with this # reck model # ser # there is no problem getting the parts for whrlpool . the motor and fan are normal service parts but the mounting bracket would have to be ordered . as the do not ware out . ****..
Dec 23, 2009 | Refrigerators
PROBLEMS WITH MODEL 59516.731
- Check if the fan blade is not broken or unbalance fan blade.
- Check if bolts are tight enough.
- Check if the fan motor rubber grommet is complete and balance.
- Check also compressor rubber grommet is complete.
- Re tight all screws and bolts on the condenser unit.
- Check the condenser installation if balance.
Jan 03, 2008 | Dometic Rooftop RV Air Conditioner
Condenser fan mounting
Most condenser fan turn ccw looking down into the unit and should be mounted about 1" from motor. A good check is that the air is moving up and out and drawing through the condenser. Thanks
Aug 08, 2007 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
