Question about Ricoh KR-5SV 35mm SLR Camera
My Ricoh kr-5sv's rewind button is still pressed in after i rewound andd took out the film. how do i get it to pop out again?
    Scholar:
  • 80 Answers
The rewind button will usually pop out once you turn your film advance lever. In order for you to be completely familiar with your camera, here's a link to a user's guide in pdf format:
http://www.butkus.org/chinon/ricoh/ricoh_kr-5sv/ricoh_kr-5sv.htm
Hope this helps.
Posted on Mar 25, 2011
The film ripped from the cassette on a contax rts when i was manually rewinding it. is there any way to salvage this at home? also, what is the best way to remove the film from the camera, without damaging...
before opening the camera, press the film rewind release button and ensure that the portion of film which remains attached to the cassette has been totally rewound. Next, with the camera in total darkness, open the camera back and remove the film cassette. Grab a firm hold of the loose end of the torn film and tape it to a piece of wooden dowelling and then turn the dowelling so that the film pulls out and winds onto it. Once the film has disengaged from the camera, place the dowelling with the film into a totally light-proof container: an old but spotlessly clean metal tin, such as a custard powder, cornflour or even a paint tin will do the job. Don't use a plastic lidded tin as the lid is always slightly translucent and will fog the film. When the tin lid has been firmly closed with the film inside, you can take the tin to a specialist processor and get both film portions developed.
Note that specialist handling of this type regarding development is not cheap. You cannot use a regular postal processor or minilab as their machinery cannot handle damaged film, only a professional lab (or a well-equipped friend) can individually process your film. Bear the cost in mind, as it's only worth doing if you are sure that there are valuable/irreplaceable images on the film.
Also note that by pressing the rewind button before pulling out the film, you are largely using the camera as intended so will not damage it. Afterwards, check the camera thoroughly and clean out any broken film fragments.Torn film is sometimes down to a manufacturing defect in the film, or due to the rewind button popping out during rewinding, or rewinding much too fast or due to excessive resistance in the take-up mechanism as the film is rewound; the latter usually indicates that the camera is overdue for a professional CLA (Clean, Lubricate, Adjust) service. The fault may commonly be due to a combination of those factors.
Sep 13, 2011 | Contax RTS II 35mm SLR Camera
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jan 21, 2011 | Nikon N65 35mm SLR Camera
I have a 36 exposure film in the camera with 25 pictures taken and I want to remove the film without taking more photos. How do I rewind?
To rewind the film mid-roll, press the two film rewind buttons simultaneously for one second. The two buttons are marked with a red film symbol, and double as the Auto Exposure Bracketing button to the left of the viewfinder and the Aperture/Exposure Compensation button to the right of the control panel.
The film is completely rewound when a blinking "E" shows in the control panel.
Sep 08, 2010 | Nikon F65 35mm SLR Camera
Don't know how to open the film door
To open the film door just pull the rewind crank upwards. Make sure that you have rewound the film first though! (press the rewind button on the bottom rear right of the baseplate, and then turn the rewind crank clockwise until you feel the film disengage from the take-up spool).
Please take a moment to rate my reply.
Sep 03, 2010 | Pentax ME Super 35mm SLR Camera
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
Aug 23, 2010 | Nikon F65 35mm SLR Camera
I don't know how to open the camera to put my film in...
Press the shutter release button to ensure that the shutter is released, then pull up the film rewind knob until the back pops open.
If you need a manual, you can download a PDF one from http://www.butkus.org/chinon/ricoh.htm
Mar 24, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
What is the button on the bottom of Olympus Stylus zoom 140
No. You just rewound the film. The pictures you took are safe, but you probably 'lost' the rest of the film you did not shoot.
Jun 19, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Film
It's a 35mm camera, so it uses 35mm film (sometimes referred to as size 135).
You can download a manual from http://www.butkus.org/chinon/ricoh.htm
Mar 28, 2009 | Ricoh KR-5SV 35mm SLR Camera
Problems rewinding film.
Your film is already rewound (if I understood you correctly). Your camera is beeping because the film is rewound and there is no film for the camer to take the photo on since it has been rewound.
Jul 09, 2007 | Canon T70 35mm SLR Camera
Ricoh KR-5SV 35mm SLR Camera Logo
109 people viewed this question
Top Ricoh Photography Experts
Lyle Siemens
Lyle Siemens
M_Butkus
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
