Air conditioning pipe outside leaking
I live in a two story townhouse with an attic and there is a pipe that sticks out from the vinyl siding in between the height of the second floor and the attic that I believe is a draining pipe for codensation for the a/c. Today I noticed that the pipe is leaking excessively. It is hot (90+) and humid here today and the a/c is running almost constantly, but it has been 90+ degrees every day for the past two weeks. Should I be concerned or can excessive drainage be relatively normal every once in awhile.
Thanks
  • 182 Answers
That water is the humidity that is being removed from your house.It is a sign that your system is working properly.
Posted on Aug 03, 2008
Air condition is in attic but is leaking water from a pipe that is staining house & dripping on the roof of the porch why does it do that?
An aircon condenses water vapour from the local atmosphere. At times of high humidity the amount of liquid water produced can be considerable and must be allowed to drain away safely.
The answer to your problem would be to move the pipe or to modify it, perhaps by extending it all the way to the ground.
As the aircon is in the attic it is probably higher than the rainwater guttering and it might be possible to move the pipe so it drains into the rainwater system.
May 20, 2017 | Heating & Cooling
Where is the drain pipe on my a/c? Ruud #UBHC-21J11SFC. Do I have to take something apart? The pan under unit fills up and overflows. It is leaking through the ceiling under the unit. I am a woman. ...
The drain or drain piping (usually PVC piping) is under or on the edge of the drain pan, under the unit. It has to exit outside some where. Either down thru the wall into the crawl space and out thru the foundation wall. Or thru the attic to a gutter outside on the edge of the soffett. Look for white PVC piping outside the house where I indicated. Then you can use a garden hose and high pressure to unclog it from at it's termination point, by back flushing it.
Hope this helps you. Please let me know. Thanks
Jun 19, 2011 | Ruud UBHC Air Conditioner
Air ring leaking on 18 foot pool....cant find leak...if it is the seam how do i fix it???
To be honest, ive seen 20-30 customers come to my company looking to fix this same problem. Weve tried vinyl patch after vinyl patch, and several different cement fixes. Nothing works.
The best results ive had are with a simple vinyl liner repair kit.
The most important thing is to let it sit for 48 hours before reinflating, but even this fix was only temporary.
Long story short, you get what you pay for, and intex is the cheapest pool systems on the market for a reason. The air ring always starts to leak right after the warranties are up, and the Intex company just plain out doesnt care.
Wish I had better news.
Mar 29, 2011 | Intex Easy Set Pool 15x36
Don't know where my condensation line drains
If the blower is in the attic try the gutters outside,or a vent/wastepipe nearby in the attic.Follow the pipe from the bottom side of the unit.
Sep 23, 2010 | Ruud UBHC Air Conditioner
Have a 1984 trane heat and air gas furnace unit ..always freezes up...repair people always come and put freon in it over and over.. and of course blows out pipe. Had new outside unit put in this is a...
Could very well be.
Seems to me when they replaced the outdoor unit in 1996 someone should have found out that there was a leak when a vacuum was supposed to be pulled and held on the existing line set and and the unit in the attic for a period of time.
A known leak is supposed to be found and repaired.
find a company that is willing to spend time and find your leak.
Most likely it is in the line set going to the attic or the indoor unit in the attic behind the wall.
Jun 14, 2010 | Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Wet floor passanger side
Air conditioning drain stopped up with debris (leaves,pine straw,sticks). Small tube sticking out from firewall with rubber elbow pointing down behind engine, passenger side. If elbow missing air will cause water to back up into vehicle. Another possibility, if your coolant is low heater core leaking.
Sep 27, 2009 | 2002 Jeep Liberty
Dryer vent filled with water. Large loads would not dry.
If the drying problem is caused by poor venting/air circulation, then things probably won't improve until that situation is remedied. Check out the link I am attaching. It contains dryer venting requirements. Hope this helped and I'm sorry for your trouble. Best wishes.
http://www.mediafire.com/?4yazrf2jz3d
Sep 07, 2009 | Dryers
My air conditioning units work. They are cooling. The thermostats say 76 degrees. The problem is the hot dry smelly attic-like air that is constantly circulating and blasting down on me from the air vents....
the techs probably checked the units operation,but did they get in the attic to see that the duct work on the return air side of the unit is tight and not sucking in the attic air.
Aug 05, 2009 | Heating & Cooling
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
