Question about Indesit DF125 24 in. Built-in Dishwasher
My IDF125 starts OK, the water gets into the system cabinet but then the programme just seems to hang. Prior to pressing the start button the LED above the start button flashes slowly. If I reset the system by holding the power button in and then restart the programme the pump first drains the cabinet so the pump and feed appear to be working OK. Any ideas, this machine is only a few months old but I've lost the receipt so can't easily get it back to the supplier. Help!!!
  • 27 Answers
SOURCE: Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Posted on Jun 26, 2007
  • 18 Answers
SOURCE: INDESIT IDL705
Sounds like an water inlet valve problem
Posted on Jul 12, 2007
  • 159 Answers
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Posted on Aug 06, 2007
COXY
  • 76 Answers
SOURCE: Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Posted on Dec 04, 2007
SOURCE: Indesit IDL705
use descaler
Posted on Apr 03, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Samsung j1455av front loader washing machine lcd control panel frozen
when you disconnect from power you should wait about 5 minutes prior to reconnecting. Also check the panel to be sure you didn't place it into a "lock" mode. This can be corrected simply pressing the correct selection(s) to "unlock" the control panel.
Make sure the dispenser drawer is fully closed as some units prevent operation until properly sealed to prevent water leakage.
Nov 22, 2017 | Samsung Washing Machines
How to discale the unit
Delonghi EAM, ESAM, ECAM, Nespresso
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the appliance displays the message:
DESCALE
you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RISRINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Jan 01, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale
DESCALE
Proceed as follows:
DESCALE No
DESCALE Yes
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Dec 31, 2017 | Washing Machines
It went to welcome screen and after i typed in my password, got a black screen that says insert disk and press F1 or press F2 and something about setup.
This happens whenever one closes any installation prematurely. Insert the disk then properly cancel or complete the setup and restart the computer you wont get this message.
Jun 22, 2010 | Dell Dimension 2350 PC Desktop
System hangs at screensaver at dell desktop 745
well try this
- > disabling startup programmes but not un-installing : Start -> Run -> type msconfig & press enter -> select startup tab on the top -> click on disable all. Apply & OK... computer restarts...
then
-> delete prefetch : Start -> RUN -> type prefecth & press enter -> in the window select all and shift delete.
then try performing disk cleanup ...
Sep 26, 2008 | Dell OptiPlex GX520 PC Desktop
Wont start on any program
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Water from faucet shd be in good pressure. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
& rate me pl.
May 05, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Indesit DF125 24 in. Built-in Dishwasher Logo
100 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
