Question about Hoover Dishwashers
How do I reset a Hoover aaa class dishwasher the power went off halfway through a cycle
3 Suggested Answers
  • 4 Answers
SOURCE: error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Posted on Mar 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: Mybosch dishwasher quit today halfway though its
Hi, Welcome to Fixya,
Based on your description, "does not light up, there is absulutly no power, i alread reset the breaker and that did not solve the problem" it sounds like a burnt connection in the junction box.
**I would start by first shutting off the breaker...safety first**
Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. i.e. macmarkus_12.jpg then observe here...remove the connectors a visually inspect the wires...it may in fact be obvious before removing the connectors. macmarkus_13.jpg This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
The end result is no power to the controls. Check it out and post back what you find.
Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck.
Regards,
Macmarkus :)
Posted on Nov 07, 2010
Whirlpool AAA Class Dishwasher
FA - Aquastop error
Check water supply. Low water pressure? Does the machine fill up with water in under 1 min? If not, thats your problem. If this happens during wash cycle, it could be the intake valve for the rinse cycle that is your problem, if you hava doubble/tripple intake valve that is.
Feb 17, 2016 | Washing Machines
My Siemens dishwasher quit halfway through the cycle. It will not power up at all - all lights are off. It's as if the breaker was tripped (but it wasn't). Is the thing fried? Doesn&am
Take off the toe guard plate at the bottom under the door. There may be a fuse holder in the metal box that the power cord connects to.
Jan 12, 2015 | Siemens Dishwashers
The DSFN 1530 AAA Class dishwasher won't start. the lights are on. there is water in the machine.
Could be the door interlock switches. There are usually two of these. I removed them on my GE and replaced them with an illuminated push button kill switch.http://www.auberins.com/index.php?main_page=product_info&products_id=360
When switch is on the control panel is powered up as well as the rest of the unit. If you need to add a dish after activation you just push the button before opening the door and it interrupt the cycle which resumes with another push.
Sep 04, 2014 | Dishwashers
Stops halfway through wash cycle
Replace the cycle/timer unit ... the timing gears are damaged
Aug 30, 2014 | Dishwashers
After a power surge yesterday my hotpoint dishwasher is doing this halfway through the cycle. It doesn't finish the cycle - water stays cold and it doesn't dry the dishes - any ideas's? The model is
Try cutting off the power to the dishwasher at the breaker box to reset the memory board ( for 15 sec.) then turn the breaker back on. If this did the trick good if not then the power surge may have over powered the board inside.
Oct 14, 2012 | Dishwashers
HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER INITIAL RINSE & REFUSES TO PROCEED TO WASH CYCLE WHATS THE PROBLEM?
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
Jun 01, 2010 | Hoover 24 in. HD83M Free-standing...
Hoover 205 washing machine
The actuator arm for the out-of-balance safety switch had become misaligned from the safety switch. As such, it had tripped but could not be reset.
Jul 03, 2008 | Hoover Washing Machines
Error e3
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Dishwashers Logo
125 people viewed this question
Top Hoover Dishwashers Experts
Jose Pino
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
