Question about Canon EOS-AE-1 35mm SLR Camera
I have my late grandfather's Canon AE-1, and when I first got it I used it quite a bit, worked great. Unfortunately, for some reason it started taking blank pictures and I lived in a fairly rural area and couldn't find any repair shops. I had 2 blank films from Walmart and 1 blank film from Target, so I know it's the camera and not the developer (as it has been in the past). Due to moving, it has been stored in the top of my closet for a year or so. If it can be fixed, I would like to use it again, but due to the sentimental value I really don't want to mail it away someplace
  • mamalacroix Mar 25, 2011
    Thanks. I was thinking it was the trigger release, but wasn't sure, since I am far from an expert. We do have a couple digital cameras as well, it's more the sentimental aspect that keeps me from getting rid of the Canon.
    Problem Solver:
  • 4 Answers
Fortunately the older SLRs are mechanical and pretty simple to detect problems with. Without being there and having a "hands on" experience with it, my first explanation would be that your shutter is not functioning properly, (opening and closing) when you trigger it. This could be caused by dust or a faulty trigger release. It then needs to be taken apart and cleaned, and or mechanically checked for obstructions or broken parts from the trigger to the shutter. Either way, it's costly to have a shop perform these operations and there are few that do that anymore. You might want to consider going to a DSLR. Not to push you in that direction or try to sell you one....but I do have a Nikon D80 with 5 lenses and a metal carrying case available.
Mitch
Posted on Mar 25, 2011
  • ejandco Mar 25, 2011
    Cool. Another thing you can do is open the camera back with no film in it. Advance the film advance until it stops and then release the trigger like you're taking a picture. From the back that is open, look through the lens where the film would be. If you don't see the iris open and close at trigger release, it's done. Then refer to the above resolutions.
Canon T3 flash flutters and does not take pictures help!
The 'fluttering' is a pre flash used to help the camera focus in low light. The internal flash isn't a powerful flash and is usually only good enough for subjects up to about 2m away in reasonable light also to light a subject that is back lit. Try putting the camera in manual mode (M) 1/60sec on f5.6 flash popped up review it and make adjustments accordingly i.e. open up or shut down the aperture as the flash usually syncs at 1/60
Aug 13, 2017 | Canon EOS 1100D / Rebel T3 Digital Camera
What kind of battery does my Canon AE-1 take?
The AE-1 uses one 6V battery, either a silver-oxide Eveready 544 (or equivalent) or an alkaline-manganese Eveready 537 (or equivalent).
If you need a manual, you can download one from
http://butkus.org/chinon/canon/canon_ae-1/canon_ae-1.htm
Jan 26, 2011 | Canon EOS-AE-1 35mm SLR Camera
Can my canon AE-1 operate without batteries?
The Canon AE-1 was a technically advanced camera when it first came out the "E" in AE stands for electronic. The whole camera depends entirely on a battery. The short answer to this question is No it will not function.
Oct 24, 2010 | Canon EOS-AE-1 35mm SLR Camera
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
How do you change the prism on a canon AE-1
The prism is a major repair. If the prism is damage the the camera is trash. If the focusing screen in fornt of the prism is scratched then you can replace it if you can find another one. Because the camera is so old you will not be able to get them from Canon. Because of the age you may be better off buying another used AE-1
Sep 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
25 year old Canon AE-1 Program SLR camera mirror suddenly stuck up. I can catch the edge and gently pull it away, but it returns back to the stuck up position. I have already rewound most of the film back...
I wonder about answering posts that are a year old but here goes. The Canon AE-1 Program is a solid working classic but unfortunately Canon won't repair them anymore at least not in m y country anyway. However there are many individual repair people still bringing these cameras back from retirement to full service. Check with a local camera club or cruise e-Bay I've seen auctions selling service for these cameras in the US for as little as $79.95.
Sep 13, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Golden Technologies Avenger Bateery Problem
Battery needs replacing when that happens.;
Regards; Aaron
Aug 27, 2008 | Golden Technologies Avenger 3 Wheel...
Canon EOS-AE-1 35mm SLR Camera Logo
264 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
