I have a horizontal magic chef gas heat/cool furnace (circa 1980) located in the attic. In the summer with the thermostat off and the fan switch on off, the fan on the unit will turn on all by itself when the attic temperature reaches around 100 degrees thus blowing warm air into the building. I have changed the thermost with same result. This fan is getting power from someplace. Nothing is on the wiring diagram showing a temperature switch on the unit. Where should I look to find what is causing the fan to come on?
    Guru:
  • 683 Answers
It has a thermister on it, but would recommend an attic fan will keep attic cooler and save money on cooling bills.
Posted on Mar 25, 2011
We have royal red furnace to heat our home.The fan dose not stop.
Details.......does the furnace function normally otherwise? Might just be a stuck fan switch. Make sure the thermostat hasn't been set on Fan ON setting or summer air circ. on older furnaces.
Find the fan switch and tap it and see if fan quits. If it does,fan switch is bad.probably. Always make sure your air circ. filter(return air to furnace) is replaced every 3 mo. or so,too. don-ohio (:^)
Jan 03, 2017 | Royal Heating & Cooling
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
Will not switch off
make sure the one that says "cool, hot, and off" is switched to off.
Mar 02, 2014 | WHITE-RODGERS DIV 1F56N-444 Universal...
My honeywell thermostat will not let the fan blow if it's on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board.
Dec 17, 2013 | Heating & Cooling
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
I can't find the summer switch on my furnace model FG6RA 072C-12A
there isn't a summer switch - the thermostat will switch the operation from heat/winter operation to cool/summer operation. I.E. "Cool" for Summer and "Heat" for Winter.
Aug 05, 2011 | Heating & Cooling
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Rheem furnaace blower stays on
On a furnace the fan is controlled by a computer and a sensor ot a oldstyle fan thermostat. Basically it waits till the furnace heats up a little and then turns it on and after it shuts off it will run till the thermostat cools back down may take a few mins. In cool mode the thermostat controls the fan so it shuts down immediatly. This is why the thermostat asks you if its electric or gas heat. Should have a switch somewhere for this.
Nov 19, 2007 | Heating & Cooling
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
