Question about Sanyo Televison & Video
Sanyo dp46840 lcd tv,, Tv power led will turn on but no pic or sound,, i checked main fuse and cap's on psu, is there a problem with this model#?
  • 2 more comments
  • Matthew Albert
    Matthew Albert Mar 25, 2011
    This is a LCD!! The power led stays blue when power is turned on,, as i posted in my first post i checked all the cap's on the power supply..
  • Matthew Albert
    this power supply has the light ballast on the same board,
    Any known proublems with this tv?
  • Matthew Albert
    this tv has been unpluged for a few weeks,, what should i look for on the power supply?
    I got 120 ac coming out the plug, but at Fuse1 its only 61 AC? this is not right is it? what would do this??
  • Matthew Albert
    nvm i tested the fuse to the boards ground,, i get 120 ac when i tested it from plug to fuse
    Genius:
  • 1,126 Answers
Your main TV processor is locked up, unplug from wall for 40Min, and it will rest back to normal.
If that don't work, then you have power supply problems.
Posted on Mar 25, 2011
Testimonial: "ty"
  • Veril Gillette
    Veril Gillette Mar 25, 2011
    Yes I know what type of TV it is, try to reset or replace power supply.
  • Patricia Mitchell
    Patricia Mitchell May 11, 2012
    I've replaced the power supply 3 times and it hasn't solved this problem. The first time we figured the replacement board was defective so we exchanged it; but that one didn't work either so we exchanged it again. Still no luck with the 3rd board. We are looking for other possible solutions to this problem.
  • Sanyo Master
  • 6,993 Answers
is the power led on the TV red. If yes, then it means the TV is having a power problem. It not that there is a problem with the model but electronics cannot be relied upon 247. Power entering into the TV most times is what damages the TV.
This issue described is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
I have a samsung tv 40 lcd you turn it on it makes a sound then no pic but is still powered up
There are hundreds of different models of Samsung LCD TV using numerous methods of screen illumination.
what model?
it could be a faulty PSU or faulty LED strip and unfortunately if you are asking what is wrong, you are unlikely to be able to diagnose and fix.
an LED strip would mean a large disassembly job with a very high risk of damaging the fragile LCD.
a PSU fault would mean knowledge of working with mains powered electronics or you could take a punt and just buy a replacement PSU although it is unlikely to be this if sound is still present.
someone with knowledge of TV repair really needs to be fixing it as diagnosis over the web is impossible, even for a repair technician like myself.
Jun 17, 2018 | Samsung Televison & Video
Rca tv powers up has backlight no sound or picture replaced main board and inverter
I would check the input board for correct power supply input
check the blue 15pf 6kv caps near the output from the PSU to the inverter.
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
Sanyo LCD 32XR8DA i cant turn the tv on by remote or by pressing the button on top of the tv
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 26, 2014 | Televison & Video
Sanyou DP26746 LCD TV Has sound, No picture, Has backlights, LCD is active
It sounds that the main digital board to your TV has damaged. But, before make it confirm, a through check should be done. Contact any experienced service technician for help. The work is skilled one, that a user cannot do it with ease.
Jul 16, 2012 | Sanyo DP26746 26 in. LCD Television
Does my dp46840 need the shroud over power supply?
Not likely. The shroud is used for keeping out interferences. Not your case tho...
Jun 11, 2012 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
Model DP26649 No pic no sound no warning. Shut off last night and dead today. Will be 2 yrs old in August.
Now the tv it is completely dead no LED power light indication is on at all or the tv power LED light indication blinking too?Check the power source?Tries tv unplug,replug it back about an hour later for the tv do a resetting itself back to the factory setting,tv should be working again.If not the tv power supply board it is dead,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 17, 2011 | Sanyo DP32746 32 in. LCD Television
Orange Led syndrom
I found the following solution on internet:
VIEWPIA LCD
Make: Viewpia
Model: LC-32IEB2
Fault: Unit held down with only orange LED lit
Remedy: Remove the main metal screen cover from main board and check the input
voltage on to the main 3.3Volt regulator IC202 it should be bang on more or less
5Volts, if not replace capacitors C905 330uf 10v C908 470uf 10v both are to be
found in the main power supply section.
J Williams
www.jvsvisual.com
Unfortunately I'm not very technical so now I will need to find someone to do this for me...
Dec 22, 2008 | Televison & Video
Televison & Video Logo
1,817 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
