Question about SanDisk Sansa Clip MP3 Player
Getting Out Of F.M. Mode
My 2GB CLIP PLAYER WORKS GREAT. BUT WHEN I SELECT THE F.M. MODE. I CANT GET OUT OF IT. IT PLAY'S F.M. GOOD, BUT I CAN'T GET BACK TO THE MP3 MODE. I TRIED TO RESET THE PLAYER BUT IT STAYS IN F.M.
hbhju2@roadrunner.cvom
  • 8,596 Answers
Use the button that looks like a house on the front of the player
Posted on Aug 14, 2008
I have a philips GoGear 2gb I have only 35 songs and I can't get the songs to shuffle as soon as I try it stays paused.I can go to artist and play one song at a time searching each time.
Please select the sound mode in the menu and select the Shuffle mode . If the player refuses to work then it is better to have the player reset using the reset button.
Mar 23, 2011 | Philips Audio Players & Recorders
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
http://forums.sandisk.com/sansa/
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2GB to my computer it doesnt show in My Computer section so that i can down load music into it
just figured mine out. turn your clip off. put the slider in the hold or lock position. press and hold the center button on your clip. continue to hold while attaching the usb to your clip. keep holding the center button as clip powers up. after appox. 12-15 seconds, your computer should read the clip. i am running windows xp and this is the ONLY way my comp. will read the clip. but it works great!! good luck!
Apr 23, 2009 | SanDisk Sansa Clip MP3 Player
My pc wont let me install new sandisk 2gb mp3 player
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
Hope this helps!
Apr 02, 2009 | SanDisk Sansa Clip MP3 Player
Sansa 2gb clip
While the player is connected to the computer, you will not be able to go through the menu, play music, etc. Only after you have disconnected it from the PC will it work.
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb lockec
First of all, may I ask if you have a mini disc player or a Sansa Clip? Because the Sansa Clip does not play discs of any kind.
If you do indeed have a Sansa Clip you will find the FAQ rather helpful here - http://www.sansa.com/support/sansa_clip/faqs
Question 9 there is regarding devices not recognized by the PC and the solutions are as follows:
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
Clip: Go to Settings > USB mode & choose MSC
If none of the solutions work for you, please post the results of your attempts and we can go from there.
Dec 27, 2008 | Audio Players & Recorders
Sansa Clip 2GB MP3 player
The user manual wil lshow you how to switch your USB mode from MSC to MTP:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
Where can i find the driver for sansa clip mp3 2gb? where i can find the driver for sansa clip mp3 2gb
Go to sandisk.com. Click on downloads. Select sansa clip from the product list, then your operating system. You can get the updated driver and user manual.
Dec 10, 2008 | SanDisk Sansa Clip MP3 Player
2GB SD Card Problem.
you cant expect all mp3 players to play as many songs as u wnt. each mp3 player has a limit of memory card that needs to be attached. see whats the maximum memory your mp3 player can support. and also see if you can locate all the songs when the SD card is connected to your computer
Jan 29, 2008 | iLO MP3 Player
SanDisk Sansa Clip MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
