Question about BenQ MP720p Multimedia Projector
Error message--the filter cap is not on correctly then the power shuts off
  • 442 Answers
Check that the filter cover is correctly installed and the little switch is activated by the cover
Posted on Mar 26, 2011
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Kenmore Washing Machines
When my washer gets done with the rinse cycle, it stops and reads F 02. Then shuts off. What do I do?
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Check Fuel cap message displayed with cap on
That means a few things, your cap is not on correctly, it is not on tight enough, or the seal one the gas cap is bad and you need to replace the cap. I would first try to take the cap off, and then put it back on and make sure that you hear the clicks, if yours does not click then I would make sure that the cap is on nice and tight. If that doesnt work after a few days, then I would replace the cap. The problem is though that you will need to start and shut off your vehicle at least 15 times to reset the error message to make sure that you fixed the problem, unless you can clear the code with a OBD tool. Please rate
May 27, 2010 | 2003 Lincoln Navigator
Panasonic DMR-e80HS won't play
L2 is not an error message,it is the indication for LINE2 input.
Messure the 12 and 5 V lines ,if not correct i would suspect some bad caps in the power supply
Jul 24, 2009 | Panasonic DMR-E80H DVD Recorder
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
Apr 10, 2006 | Panasonic SC-PM08 Shelf System
BenQ MP720p Multimedia Projector Logo
302 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
