Question about Hitachi CP-X1250 Multimedia Projector
The filter needs replacing. Do you sell replacement filters for model CP-X1250?
  • 442 Answers
Take the filter to the local electronics repair shop and ask them for some filter material like the one in the unit. Then cut it to size to fit like the old one.
Posted on Mar 26, 2011
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Is the only difference between at CP-X1200 and CP-X1250 the bulb, or is the ballast circuit different too? Just thinking how easily I could boost the brightness from 3500 to 4500 lumens.
Model: CP-X1200 ( Lamp)
Part#: DT00591
Lamp Type: UHB
Wattage: 275 Watts
Lamp Hours: 2000 Hours
Model: CP-X1250 ( Lamp)
Part#: DT00601
Lamp Type: UHB
Wattage: 310 Watts
I'm not sure but I would think the same ballast board is used, and the trimpots adjustments set in the factory.
If you fiddle with it, you may not be able to get the tube to strike on startup, or worse you can explode the lamp.
Also the extra heat generated may degrade the optics and LCD panels.not mention melting the housing.
Better to leave well alone.
Feb 18, 2011 | Hitachi CP-X1200 Multimedia Projector
Color shift blue tint
This could also be a setting. If you are using component video as a connection, make sure that the unit is set for RGB if coming from a laptop or other computer system. If the projector is set to YPrPb, the picture will look purple or bluish as you describe. Change the setting to RGB and all should be well.
Dan
Oct 26, 2009 | Hitachi CP-X1250 Multimedia Projector
Locate filter
The air filter for the Hitachi CP-S240 is located below the lens if the projector is sitting flat on a surface.
There will be a plastic cover that slides off by pulling it towards the front of the machine. Inside this cover you'll find the filter.
To clean it, simply pull the filter out of the cover or housing and blow the dust out of it. Replace the filter and the cover, and then make sure to go into your menu and reset the filter timer.
Jan 05, 2009 | Hitachi CP-S240 Multimedia Projector
Bulb
Instructions How to change Lamp in Hitach CP-X1250 are available on User Manual page-38
Please confirm do you have User Manual?
Oct 01, 2008 | Hitachi CP-X1250 Multimedia Projector
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Hitachi CP-X1250 Multimedia Projector Logo
130 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
