Question about Samsung Computers & Internet
How can i run 4 monitors to put out one total screeen.. ok lets say i take 4 montiors and put like two 15" monitors and stack them with antoher 2 under it so its a box of 4 .. 2 screens wide by two screens high.. how can i make them out put to one screen total so when all 4 monitors = a full screen view
    Scholar:
  • 84 Answers
In order to do this, hardware wise, you would need 4 monitors and enough graphic ports to support them.
Older graphics cards may only have two graphic ports which means you would need to have 2 videos card installed on your machine in order to get 4 displays going.
On some of the new graphics cards, you can get as many as 8 ports on the same card meaning you could drive 8 displays with one cards.
Once you've got the right hardware, you can either use the manufacturer's software (ATI or nVidia most likely) to configure your monitors to run as one desktop or you can try using Windows built-in display settings. The key is you want to extend your desktop onto all the monitors and to tell your computer which screen you want where.
If you need any more help with that, let me know.
Posted on Mar 25, 2011
In minecarft what does this mean: hs_err_pid#
This error could be related to two things, a corrupt java installation or an issue with the graphics driver.
Try first to reinstall the java engine first, if that fails try to reinstall the graphics driver.
Chances are it is a Java issue.
Good luck.
Jan 22, 2013 | Microsoft Corporation Xbox 360 Live...
Acer x163w montior says " no signal" the tower is
You need to check the VGA cable, make sure the connectors are seated properly, also try this monitor with another PC first to make sure it is not the video card problem in the PC. We need to narrow down the problem first since we do not want to open up the monitor if we have too.
Most common failure in the monitors are due to bad caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 06, 2011 | Acer X163WB Monitor
Hotmcompaq 7020 monitor will often display the following when turned on... the 'title page' showing Compaq. Then a rectangle shows up that says "searching for analog signal" then few...
That is the OSD brain, inside said monitor
The On screen display , window.
push the menu key on said monitor, see that MENU now?
sure. that tells you the monitor is basically OK.
that message means the unstated PC, is not sending any video or sync signal (or its cable is bad or unplugged or loose)
or the funny timer is tripping.(out)
monitors evolved like 5 times from year 2000.
so first i carbon date yours, to see what you actually have.
FP7020 is not a TFT7020, got it.
i wish i could read the service tag on it so i can be accurate but i cant.
no matter both are now RETIRED. at HP (hp is compaq , a fact)
https://support.hp.com/us-en/retired-products
Zero support now... no books, no nutt'n!
the first monitors, had a timer inside, and a clock that had a auto sleep mode, inside it, yah. they did, and is a pain .
lacking the book , one cant know that can one.
seems its 2002 carbon dated. wow 15 years young , ouch
this is the year the VESA rules went in to effect.
long ago, and changed 4 more times. dig>?
found a 15 years old product sheet on this old display
shows"internal sleep timer" yup, I just knew it was there,....
first make sure its off. (this must be OFF)
if its on and the clock inside is set wrong, it will trip off , at odd times.
let me explain back in the dark ages of monitors.
they had many PC that had no sleep mode
so HP(old compaq) put a clock(time of day) and sleep timer in dislplay., (for US gov, energy STAR bs)
so what you do is first set the OSD clock to the correct time.
then in the same menu system turn off the magic clock.
magic is that only this old junk has this display
or
test the monitor on another pc to see if its monitor issues or not.
lets not say , the monitor , is ok, and its funny INANE sleep timer is shut off.
what next, well the PC is next.
but wait you never told what PC, ?
so it can be any of 10,000 different models , VGA cards, chips and OS.
endless possibles for 36 years of PC evolution.
hopeless on my end to speculate.
NOr did you say what OS you are running.+
All PCs shipped new have shipped with sleep turned on in windows
or is this running OS2 or LINUX.
in WINDOZ
click control panel
there click power settings
there, click custom settings and give it a name, and then pick
NO sleep, no Hibernate at any time.
then turn off screen savers if on. most are off default.
when the PC wants to sleep it stops the Sync lines on the VGA card
or GPU chip.
the monitor sees that and goes to sleep. all do.
if the card is bad, its bad.
if OS is corrupted reload it.
if the PC runs ok on other monitors you cable is bad.
if the cable is ok the and PC is ok, then the monitor is bad
simply move the monitor to other PC
simple move pC to other monitor, and 1/2 the possibles are now know... in 15 min work, about.
Jun 24, 2017 | Compaq FP 7020 17" Flat Panel LCD Monitor
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
I own a Hitachi 10CFR Table Saw. My question is: Can I load a Dado Stack onto the Arbor of this table saw to create a 3/4 dado cut? I've read everything from "Yes" to "Absolutely Not"...
After doing some research, I found that hitachi only recommends up to a 1/2 dado for this machine with most of the users agreeing that it probably does not have the stability or power to run a 3/4 inch safely. Meaning you probably can run the 3/4 but at you own risk.
Mar 03, 2011 | Hitachi C10FR 10" Job-Site Table Saw 15...
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Speaker sound
If your monitor has speakers built in, then you need to run a lead from your soundcard on the computer to a audio port on the monitor. It is normally hidden away near where the video cables etc plug in under the back of the monitor.
Hope that helps. =)
Apr 11, 2008 | Mag Innovision InnoVision LT 565 15" Flat...
Cleaning inside of monitor
i never heard of cleaning a moniters internals. but yeah go ahead. use a artist medium paint brush and compressed air. watch out for compassitor it will still have a live charge even if unplugged.
Feb 03, 2008 | SAMTRON 55V 15" CRT Monitor
Aten Master View KVME CS1774 Wavy Screen
This is a fairly common occurrence, typically due to signal loss. The longer the total cable run (monitor to computer connector) the less loss you will have. The longest KVM to computer cable I can use reliably these days is about 12-15? at 1024 x 768 at 32 bit color or 8? for 1280 x 1024 at 32 bit color. Things you can do to reduce loss: -Reduce the length of the total cable run. -Increase the quality of the cables used. I only use low loss cables now and have far fewer issues. -Change the video card, some cards can push a signal a longer distance that others. -Reduce the resolution/colors the video card displays. -Try a different monitor or if possible use a different (low loss) cable to connect the monitor to the KVM. Let us know how it turns out or if you have any other questions.
Jul 04, 2007 | Altusen Aten MasterView CS1764 4-port KVM...
Usercontrol automatically displayed when bootup
it is due to the 5V regulator ,replace that
Sep 15, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
164 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
