Question about GE Energy Star WCVH6260F Front Load Washer
It makes a lot of noise on the final spin to clear out all of the water from the clothes. That is, I have eliminated drainage issues by cleaning the pump filter and fixing the hose that was not properly positioned in the drain. I was just wondering if there is a way to know if the legs are all balanced properly. Is it just a visual inspection of the legs?
    Top Expert:
  • GE Master
  • 9,472 Answers
You can use a level that you can get at an hardware store. Level it side to side first then front to rear. Here is a video to walk you thru the process.
Posted on Mar 25, 2011
Frigidaire front loading washer will leave clothes soaking wet after final spin
Hi Friend, thank you for your post!
It appears you are having trouble with your Frigidaire washer not draining properly. Often, this is because your washer cannot dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your appliance. Best regards - Z.
Apr 05, 2014 | Frigidaire Washer water pump motor ASKOLL...
Final spin
Hello Matt, I am happy to assist you!
I understand your Frigidaire washer will not complete a final spin. Often it is because either your washer cannot properly drain and dispose of the water and detergent solution. Does your washer making a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Best of luck!
Jan 20, 2014 | Frigidaire Washing Machines
Clothes wet after spin
Hello pkoehler, thank you for your inquiry!
Often when the clothing continues to be wet in a washer, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Nov 14, 2013 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer e21 error appears after running about 20 mins into the wash cycle,i check the clothes they are still wet,although no water is still left,i go to the spin only cycle to get the...
Hello debbiecantu1 - Typically error code E21 indicates an issue with the water not pumping out fast enough. Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Dec 13, 2012 | Frigidaire ATF6000ES Front Load Washer
Candy1682d/180 will not spin with clothes in drum, empty drum and will spin what's the matter
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly, faulty pump, the timer or control board not communicating correctly.
Nov 02, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin at any time during cycle
Hello landlord guy - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
Oct 03, 2012 | Frigidaire GLTF1670A Front Load Washer
My washing machine isn't spinning clothes out all the way anymore... I have to run spin cycle twice to get water all out.
Hiya,
often when the machine needs to be put on spin twice to remove the water you will find the is an issue with the drainige, if the waist pip is pushed to far down the drainage or if you have lint build up it will greatly reduce the amount of water that can be released when spinning leaving it in your machine so i would surgest checking you drainage & pipes first to make sure they are clear enough for the water to escape
Hope this helps
Apr 23, 2010 | Maytag PAV2300 Top Load Washer
Won't drain. Won't spin.
Sounds like there's a blockage in the drain hose, or the pump. There could be a coin jamming the pump impeller. If the clothes are wet it's got to be a drainage problem...Good luck....Nomess
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
20 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
