Question about Norcent Technologies LT-2022 20 in. EDTV-Ready LCD Television
My tv dont turn on - Norcent Technologies LT-2022 20 in. EDTV-Ready LCD Television
  • Norcent Tech... Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 25, 2011
Turn on MTlogic without remote control
Buy one remote control, which have setup codes for your TV brand with its code list.
Jun 02, 2012 | Televison & Video
My Dynex 19" LCD TV
try to disconnect all external devices connected to your LCD TV then try to turn it on again then wait for a minute. if the problem persist you need to get it serviced by Dynex.
hope that helps.
Mar 24, 2011 | Televison & Video
My 27" wega was making a crackling noise when I turned it on. Last time I turned it on it made a pop and went to standby, it blinks three times, pauses then blinks again clicks and blinks four times.
pls. check your tv mains plugh is luss canaction
if not then
probulum is in side tv set so pls. dont.use tv again and cont.nearest tv tech.and solve this problum. becous cracking noise is dengered for your tv.set
* you dont. open tv back cover it your self.becous in side tv set very high voltage.
Nov 10, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My 27F522T tv turns itself on and changes channels bu itself.
hi
and first of all if u dont want ur tv to turn on by itself when you dont want it to just un plug the cord and when your going to use it just plug it back on.
Sep 16, 2009 | RCA TruFlat 27F520T 27" TV
MY EMERSON TV EWFG2705 DONT TURN ON CAN SOME ONE HELP ME FIX IT?
This is another case of " You need a qualified service technician to diagnose what is not working and replace those defective parts." This suggestion comes from an Electronics Service Technician for more than 40 years. I'm sorry I can help more. G. K.
Apr 06, 2009 | Emerson EWF2703 27" TV
I dont have vchip code fof my used tv
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Nov 14, 2008 | Televison & Video
Tv dont work
check fuse in back of tv behind lower panel right where power cord gose in to tv
Feb 28, 2008 | RCA P61930BL 61" Rear Projection...
When i turn my tv on it makes a surge noise sometimes it turns on and sometimes dont
thats a capacitor problem. you really have to bring that to a service center.
hope this helps.
Jan 14, 2008 | Televison & Video
Norcent Technologies LT-2022 20 in. EDTV-Ready LCD Television Logo
97 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
