How do i remove the clutch on a kenmore 70 series washing machine?
Hi i have ay hot point woshing machine it woshen but it does not enty the water out ive cleaned the pipes ive bidded on ay new water pump on ebay please can you help thanks
Posted on Apr 07, 2011
  • 5,370 Answers
To get step by step instructions.Please click on the link below:----- http://technoanswers.blogspot.com/2011/03/how-to-remove-clutch-on-kenmore-70.html -------------- It has instructions and diagrams to remove and replace the clutch.------ This should help.Thanks.Helpmech.
Posted on Mar 25, 2011
How do i take the top off
Posted on Jul 07, 2011
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore 70 series m# 82872120 will not drain or spin already bypassed lid switch not the solution any suggestions?
Your coupler might be bad, even if it does agitate. Also, by removing the transmission, sometimes you can loosen up the clutch enough that it will work again. This has happened to me before.
Sep 05, 2009 | Kenmore Washing Machines
I am having trouble replacing my belt on my Kenmore 70 series
i've got them down to 10 minutes, but here goes. remove the bolts going into pump, but do not remove pump . remove the transmission bolt with the spacer and this is where you push the belt through and around pulleys.. this is a little more difficult. you will need to take off the yoke spring and move the transmission pulley around until the spin control magnet catches for spin. it will begin to take pressure off of clutch. you will need a long screwdriver or something like it to apply pressure down on the clutch plate this is to allow to to slip the belt thru the bar the spring came off of and under it.. you can then pull the belts around all pulleys and put everthing back in its place and your done...
Jul 18, 2009 | Kenmore Washing Machines
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
How to remove the agitator on a Kenmore 70 series
Set the agitator down and hold with your feet. Grab the top part and pull up sharply. It will come off. some are harder than others.
May 18, 2009 | Kenmore Washing Machines
Kenmore 70 series top loader washer machine smells like its burni
you had the clutch coupling replaced sometimes i have noticed that the smell will last a few loads but no more than that
Apr 22, 2009 | Washing Machines
Kenmore 70 series top loader wont spin just loud buzzing motor noise is there a belt or are these direct drive
that is called a clutch coupling and is located behind the motor not an easy repair to do but very fixable
remove jacket of washer .remove pump.then motor
install new coupling
Apr 17, 2009 | Washing Machines
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washer 70 Series shakes badly during spin after repairs
make sure that the 3 corner triangel thats betwwn the tub support and the base is in the right position all 3 parts corners should be pointing the same way
Mar 03, 2008 | Washing Machines
Washing Machines Logo
175 people viewed this question
Top Washing Machines Experts
