Question about Canon imageRUNNER C3220 Color Copier
Why does printer say load paper when paper is loaded
  • Canon Expert
  • 287 Answers
Hello rst,
You could have a mechanical problem of course.A bad sensor or paper lift motor.Walk up to the device and verify that each paper tray can be selected and shows paper is present.If that checks ok then it may be that you are sending a print job document that the device "interprets" to be of a size that does not match any of the paper sizes that exist within the device. If it is a PDF file, make sure that "CHOOSE PAPER SOURCE BY PDF PAGE SIZE" is NOT checked.it should be off. Also make sure "FIT TO PAGE" is on. And Microsoft Word documents can be a problem. Word will try to override the settings you select from your normal print driver. Make sure the print settings in Word are correct. When a print job comes to the device there is alot more data than the document being sent. There are instructions as well and if those instructions make the printer believe that the only way the document can be properly printed is to have a paper size that is currently unavailable then the printer will prompt you to load paper. At the screen of the printer will be a picture of itself and it will indicate the bypass tray as the source to load paper as the only alternative. Again this all based on the fact that all the paper trays work normally when you walk up to use it as a copier. I hope I helped. :-) Let "FIXYA" know if I did please. SPINAL
Posted on Mar 27, 2011
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Tip
Important!: How To Load Paper In Paper Tray Properly
In the printing process, paper jam more frequently occurs on bad paper handling rather than mechanical failure of the printer. So,to ensure that printing process runs smoothly please pay good attention to the following tips before loading the paper in paper tray of your printer.
Tips:
  • Align the edges of paper neatly before loading. Loading paper without aligning the edges may cause paper jams.
CONTINUE READING...
on Sep 19, 2012 | Canon Office Equipment & Supplies
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Says "Out of Paper" even when paper is loaded.
unplug the printer then try to Aline the paper back up then turn the printer back on if it does not load take some of the paper out and try it again. If you can't get it to load try adjusting the load tray, if you still can't get it to lad go to www.hp.com enter your model and select loading paper problem and it will run a self diagnostic test of paper.
Apr 14, 2010 | HP PSC 2410 All-In-One InkJet Printer
Quits printing and screen says "need service"
A: Power the printer on and press the Load/Eject button to see if
paper will load. If no paper loads, make sure the paper isn't
curled or creased, isn't too old, isn't loaded above the arrow on
the left edge guide, and that the paper isn't jammed in the printer.
If the Paper Out light is on solid, reload the paper, making sure
the paper edge guide is adjusted to fit the paper's width, and then
press the Load/Eject button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload
the paper, turn the printer back on, and try pressing Load/Eject
again to see if the printer will now successfully load the paper.
If the printer still will not load paper, power the printer off,
remove the printer cable, and make sure all of the packing materials
are removed. If the problem persists, the printer may need to be
sent in for service and you should contact the EPSON Connection for
assistance.
Jan 13, 2010 | Epson Stylus Photo R300 InkJet Printer
Printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
Nov 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer loads paper incorrectly when trying to print
in the tray where you put the paper, there are two pieces of plastic that site on the side ,,,,, bring them close to the paper as to touch the paper.
this way the paper cannot go left or right when loaded and now will go in straight.
this oughta do it.
Mar 26, 2009 | Dell 922 All-In-One InkJet Printer
Canon imageRUNNER C3220 Color Copier Logo
48 people viewed this question
old marine
old marine
