Question about Refrigerators
Icemaker won't crush ice - Refrigerators
FRIGIDAIRE SIDE BY SIDE ... WON'T CRUSH ICE...
... makes ice and dispenses H20 just fine.
Found this solution elsewhere on line, just adjusting the white plastic "thingy" a la #2 mentioned below solved my problem, yippee!
SOLUTION:
"The most common reason for this problem is frost forming on the shaft of a solenoid that shifts the ice bucket discharge from cubed to crush.
1.Take the ice bucket out, and look at the back wall of the frig. You should see a small hole that lines up with a metal arm that was sticking out the back of the ice bucket. In the hole you can see the end of the mechanism that moves the ice bucket arm.
2. With your finger you should be able to move it up and down about half an inch or so. If you can't, you have found your problem. Sometimes you can just free them up by working it up and down a few times.
3. If that fails you will need to remove the whole panel to get access. Thaw it out, dry it out, then put a little lithium grease(very thin coating) on the shaft, and put it back together.
Sometimes the (solenoid)coil is bad, or the inside of the coil has distorted it's shape inside so the shaft won't move. Then you need a part.
good luck, let us know what you found
Posted on May 16, 2010
My icemaker won't deliver cubes despite switching from crushed to cubes on selector, what's a guy to do
you have to take apart the complete ice maker from inside the freezer as it has to be cleaned on a regular basis to operate properly. check with your owners manual, it tells you how to clean it.the ice cube shoot is the first to freeze up & block your flow of ice. it's not hard to do. all the best.
Dec 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
WE HAVE A GE REFRIGERATOR THAT IS ONE YR OLD AND IT WILL NOT CRUSH ICE. WE'VE REPLACED THE ICE MAKER AND IT STILL WILL NOT CRUSH. IS THE SOLENOID OUT BEHIND THE ICEMAKER ARM IN THE FRIG WALL? GE MODEL...
You may be on the right track. Remove the ice bucket and check the square hole behind the ice bucket in the back wall of the freezer. You should be able to move the horizontal rod in it up and down with your finger. If not, it may be frozen in one position. If so, just warm the area a bit with a hair dryer to free it. Replace ice bucket and test. Another thing which may cause that is the ice auger itself may have separated from the drive shaft. (The icemaker itself has nothing to do with making "crushed" ice. It only makes cubes. The cubes are dispensed or crushed and dispensed at the front of the ice bucket using the auger and the metal parts there.) You might also want to verify that the long metal rod (which extends past the ice bucket and into that square hole) is able to move. (it is spring loaded)
Feb 03, 2009 | Refrigerators
Ice maker in door not making ice
make sure the switch is turned on on the icemaker if it is then see if there is water in the icemaker it could be either water valve or icemaker
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working no water getting to icemaker
Icemaker is making ice slowly. Crushed ice button does work.
Aug 25, 2008 | Refrigerators
GHE monogram ice maker.
pull the icemaker out, say be one inch, shack it a bit, and jam it back in. We've done that each time we had that problem, before it started to work. The icemaker is designed poorly, my openion, and gets jammed easily each time you use the crushed ice. crushed ice jams the ice crusher, and cloggs the pathway resulting a no ice dispensing situation. Also try using only whole ice cubes, instead of the crushed ice. the less you use the crusher the less you'll have to problem. one last thing. if the ice is sitting in the basket for a while, due to poor ice despensor opening door design, the ice in the basket cloggs together causing the probelm.
May 19, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
970 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
