Question about Grundfos 505474 24-Hour Progammable Timer/Clock
I have a Seth Thomas 24 hours clock model number 0708 (708-003) The piece that holds the battery apparently has stopped working as I've tried a number of new batteries and none work. The batteries have been tested for strength and all are in half green or better. Does the mechinisum that holds the batteries eventually die? Bill Fisher/ 714-522-6434
Hi Bill
I have the same clock ~ it has a quarts movement
so the fact that the battery holder is bad should not
keep it from running = try connecting a AA battery
to the two wires (one at each end of the battery holder)
and SEE if it win't yet run ---- if so, solder the wires to
the battery and tape it in-place
Regards, John in Ypsilanti, MI
Posted on Sep 04, 2011
Seth thomas manual for models E658-E659and E662-E663 series floor clocks
Try Googling (seth Thomas)(*)(manual) without parens.
* E658, E659, E662, E663. Search models one by one.
Nov 15, 2017 | Seth Thomas Home
Please send it to msfreightbroker@msn.com. I can open it from there. Thank you so much for your help in this matter.
Hello Sandra
I've send the proceedings to set your Seth Thomas Clock adjustments by email address you've provided with your ad. Go to your amil and get it.
OK
gopakumarg43
Oct 03, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Manual for Seth Thomas Grandfather clock model # 46978
Hello
I've Seth Thomas Grandfather 46978 clocks' user manual with me. But I don't know how to send it to you. It is in PDF format. The newly hoilsted Fixya site has no facilty to send the manuals to users I thinks. I can't see it nowhere in this iste. OK.
Sep 27, 2011 | Seth Thomas Radio-Controlled Howard Wall...
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
  • 3
  • 4
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    How to set
    Hello
    Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How do I set a seth thomas weather station from a 24 hour clock to a 12 hour clock?
    Press and hold the mode button until the year starts flashing in the upper left. Tap the mode button 3 times. You will see "24hr" with the 24 flashing. Press the + or - button on the back. Press the mode button 4 more times (or just leave it alone for about 30 seconds and it will go back to the normal display).
    Mar 03, 2010 | Kitchen Appliances - Others
    Seth Thomas wall clock wont set to time.
    either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
    Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
    Grundfos 505474 24-Hour Progammable Timer/Clock Logo
    227 people viewed this question
    Top Grundfos Hardware & Accessories Experts
    Gene Haynes
    Mike Magnay
    Mike Magnay
    Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
