How do i get the cover off my accer 5253 to install upgrade memory
  • 734 Answers
Here's a general guide to RAM Replacement.
http://www.technibble.com/how-to-install-laptop-ram/
Regards,
Selk
Posted on Mar 25, 2011
How to take out memories out of your computer or notebook PC?
on a desktop computer, the RAM memory is attached the motherboard in 3 or 4 slots.
On a laptop, notebook they are hidden under a small cover on the bottom. The also fit into slots, but at in line with the case.
  • Laptop Memory Upgrades - Kingston.com‎
    Adwww.kingston.com/Memory
    This ad is based on your:
    • current search terms
    • recent searches on Google
    Visit Google's Why This Ad page to find out more, block specific advertisers or opt out of personalised ads.
    Kingston has the right memory for your PC/Laptop. Lifetime Warranty.
  • .spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
    g-img{display:block}._WCg{display:block;border:0;position:relative}
    Search Results
    How to Upgrade Laptop RAM and How to Install Laptop ...
    2q==? 2:43
    https://www.youtube.com/watch?v=pcBwnb8rENQ
    Oct 4, 2013 - Uploaded by nickscomputerfix
    Watch hands on laptop memory installation on my Acer l... ... Upgrading Your Old Laptop: Replacing RAM and ...
    How to Add RAM to Your Laptop ' PCWorld
    www.pcworld.com/article/.../how_to_add_ram_to_your_laptop.html
    You can significantly improve your laptop PC's performance by adding RAM, ... Tools: To replace or upgrade your memory, you'll need (at minimum) a good ...
    How to Upgrade the RAM (Memory) on a Laptop - Laptop Mag
    www.laptopmag.com/articles/ram-upgrade-tutorial
    Sep 4, 2014 - Here is a step-by-step tutorial (with photos) on how to find the correct RAM upgrade for your laptop and how to physically install the memory.
    How to Install RAM in Your Laptop - For Dummies
    www.dummies.com/how-to/.../how-to-install-ram-in-your-laptop.html
    The general process of installing memory modules, or RAM, in a laptop is very ... Replace the memory compartment cover and lock it down with the screw.
    Mar 04, 2016 | Computers & Internet
    Acer aspire 5253 error message no botable device after laptop was dropped on carpet
    No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
    You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
    If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
    Jan 10, 2012 | Acer Computers & Internet
    Would like to upgrade memory up to 2 Gb, found one slot only . where in the 2nd
    There are two memory slots on your computer, one of which is occupied by standard memory. You can upgrade memory by installing a memory module into the available slot.
    Installing memory
    Follow these steps to install memory:
    1Turn off the computer, unplug the AC adapter (if connected) and remove the battery pack. Then turn the computer over to access its base.
    2Remove the screw (a) from the memory cover; then lift up and remove the memory cover (b).
    50 2 Customizing your computer
    3Insert the memory module diagonally into the slot (a), then gently press it down (b) until it clicks into place.
    4Replace the memory cover and secure it with the screw.
    Jan 08, 2011 | Acer TravelMate C110 Tablet PC
    Installing memory upgrade
    Hello: there is a memory upgrade compartment on the bottom of you computer, It may had one or two screws holding the cover in place. Take off the cover and the memory bay should be exposed. Install memory of the same speed and type, you might want to take the memory with you for exact matching. There should be an extra slot for upgrading.
    Thanks hope this helps, Please leave comment
    Oct 06, 2009 | Dell Computers & Internet
    Install RAm
    Hello
    Go here http://gd.panam.acer.com/home/ and take a look at the manual for the aspire notebook 5630 (should be similar to yours)
    On page 39 theres a diagram showing the base. You basically have to unscrew the memory compartment cover , remove the cover then slot the memory in and put the cover back. RAM upgrades are really easy!
    If you found this solution helpful , please rate my solution below
    Kind Regards
    1234s282
    Jul 01, 2009 | Acer Computers & Internet
    Brothers Hl 1440 memory upgrade
    Assuming that you have the Brother HL-1440, your printer comes with 2MB installed. You may upgrade it up to 32MB maximum. However, your printer appears to use SIMM memory modules. The specs for the printer should be:
    Speed: 60-80 nsec
    Pin: 72-pin
    Output: 32 or 36 bit
    To install the memory:
    1. Turn off the printer an dunplug the power cord from the AC outlet. Disconnect the interface cable from the printer.
    2. Open the rear cover by unscrewing the two screws that secure the access cover and remove the cover.
    3. When handling your SIMM modules, pay close attention to static electricity discharges, so be careful and hold the SIMM by the sides.
    4. Install the SIMM into the slot at an angle, and then push it gently toward vertical alignment, it should click when it goes into place. DONT FORCE IT IN, be careful
    5. Re-install the access cover and secure it with the screws.
    6. Close the rear cover
    7. Reconnect the interface cable, power cable and turn on the printer.
    If all goes well, that should do it.
    May 22, 2009 | Brother HL 1440 Laser Printer
    Gateway 500x upgrade ram installation.
    hi! there if your addibg a memory card check your memory speed if match to other memory card that are installed already,they should have same speed e.g DDR PC228 or SDR PC333 so check this out before installing.But if you replace the older one upgrading,switch off your computer open cover,there is slot there for your memory card bedide your processor,at both end there a lockway,unlock your memory card and pull it out all if you have several one,then insert on one slot if that is one memory card at 2gb lock it on both end.then swich on your computer check this out on your computer properties if there is change.how to do this left click my computer,click properties.regards
    Mar 27, 2009 | Gateway Computers & Internet
    Upgrade memory on Toshiba laptop
    You'll find a small panel on the back that you can unscrew to add more memory/ram (or change the current card). Here's an illustrated guide: http://www.fonerbooks.com/laptop_2.htm
    Nov 02, 2008 | Toshiba Satellite A135-S4527 Notebook
    How to install new ram into the 2840
    Unplug the machine. On the right side of the machine you will find a cover. Remove the cover and you will find 1 open slot. The machine can take a total of 224MB (96 is built into the machine) leaving 128 available. The memory type is 100pin, 133MHz, SDRAM DIMM.
    Simply click the memory into the blank slot and replace the cover.
    Once completed, plug the machine back in and print a configuration page. The memory total should be at 224 once you have installed your 128MB.
    Good Luck
    Jul 24, 2008 | HP LaserJet 2840 All-In-One Printer
    Upgrading Memory from 256 to 1GB
    You shouldn't have to remove it, but if the system won't boot after try reversing the slot, and if that doesn't work take out the 256.
    Feb 03, 2008 | Dell Dimension 2400 PC Desktop
    Computers & Internet Logo
    David Payne
    David Payne
