Question about Parallel USB to Serial/ Converter Cable (PCABUSBX0003) Serial Adapter
I bought this gigaware usb to serial cable in order to connect to a cutting plotter to cut vinyl for stickers and things. I computer recognizes the cable, but it doesn't see anything connected to the cable. any thoughts?
  • 47 Answers
Did you load the drivers for the "cutter" it will show up as a printer...
Posted on Mar 25, 2011
  • 3 more comments
  • mattp222 Mar 26, 2011
    The cutter is a Bridge Pro-720 and I downloaded the drivers for it from the website, I also have a usb to square usb that makes the computer tell me I have an unknown device. I try to install the drivers from the website but my computer tells me that the driver has no information for the device. I have the CorelDRAW program and the Sign tools4 which claims to have the software in order to work the cutter. I have tried everything I know how to do with the exception of getting a comm cable to try. A printer showed up the other day with a name of "sign tools 4". Any ideas?
  • rsgtexas Mar 28, 2011
    try to cut to the sign tools4 printer and see if it starts...or you could have the wrong version of the driver for your version of windows...is the problem that you don't have a serial port???...there are cheap cards that give you a serial port...if a new printer showed up you may have it installed but not sure...the best bet is to try to connect it correctty...with the serial port...and load the drivers...it should show up as a recognizable name...another way it to get a serial print server...a small device that will give your computer an IP address and you can connect it to a network...I just did this with 2 legacy computers when we changed out the users PC for a WIN7 machine...that did not have the ports...
    you also may not have the port setup correctly...see this webpage...
    http://www.asigns.com/signtools/Support/...
  • mattp222 Mar 28, 2011
    So this time I plugged in the serial to serial cord and again found no success. When I go to printers and faxes, and I click on the 'sign tools 4' printer, I have clicked the print a test page but my computer makes a strange noise. Very hard to describe at that. The only sound that may be similar is the sound in a car when the power steering is being strained, but that isn't quite it. my cutter program, sign tools 4 does not give any errors and the 'document' seems to print according to my computer. The computer doesn't make any noises when attempting to cut. I am really tempted to find someone and let them check it out themselves using a remote access program.
    your best bet would be a sign person that know computers or a computer person that know signs...when you load the drivers, you normally have to specify if you are connected to the USB or the serial port...did you read the link I sent you...this is for your exact model with the same software you are using...might help...
  • mattp222 Mar 29, 2011
    Thanks, You have been so much help, but it's still not working, I had visited that link and I have read it many times. I think that the cutter just doesn't function properly or there is something seriously wrong with the 4 computers I've used to get it working with no avail. I am basically giving up on this project for now as nothing has worked at all.
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
I need drivers for Lynx vinyl express s-60 can anyone help?
I was gifted an old Vinyl Express Lynx 24" vinyl cutter. I wasn't given any CD's with the cutter. I am using your easy cut studio cutting software with my PC running windows 10. works great! I found out that I need a GCC Puma driver to make it run.
The Premier Vinyl Cutting Software
Oct 20, 2014 | Office Equipment & Supplies
I have a cutting plotter,, its a ShanghaiJintiar JT720.. works with Artcut6, <--this is what came with it. I want to use corelDraw with this plotter.. looking to make lettering with background...
basically you set corel draw to the paper size (vinly) your using.. click outside the page and set it using the selector on the tool bar..
once thats done,, click print,, select your plotter,, set your properties your using if not leave at default,, hit print..
Jul 12, 2010 | Sport & Outdoor - Others
I am trying to use my DGI Cutting Plotter and when i try to start up the program Omega Cut Pro it comes up with a message to say 'Protection Failed, Please Check Your Dongle' I am unsure what this means...
Ok this means that to use this software you MUST have a licence and along with this you get a "Dongle" a device that plugs into either the Serial, Parallel or USB port, and has a "Code" in it, that is "Read" by the software. You simply cannot use it without this "Dongle" & Licence.
Feb 10, 2010 | Computers & Internet
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
Gigaware usb to serial cable problem with vista driver download
can you see the new device in the device manager, you may need to install it, did you get disks, to install it if so go to add new hardware in the control panel and you may need to manually install the device. It will at some time ask for a disk, so have it ready, peace, Gym
Dec 21, 2008 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Gigaware USB to Serial Cable software
No need for disc, don't worry.
Radio Shack/Gigaware 26-949 USB to Serial Cable drivers (32/64bit) can be found at driverupdate us
I hope I have helped you...
Take a look, and enjoy
May 07, 2008 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
USB Malfunction
oh God. I have the same problem. but my grandparents got it for me, so i can't find the courage to throw it away. too much sentimental value. see, i put Rockbox on it. it was working fine for a while. this sucks. the good thing - you can copy/cut/paste/delete/move....etc. with Rockbox. so i just put the music on the microSD through the computer, then put it into the player and cut/paste.
Mar 03, 2008 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
870 people viewed this question
Top Parallel Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Parallel Computer and Internet Expert? Answer questions, earn points and help others
