Question about Refrigerators
My kenmore refrigerator model 57282791, the ice maker works but the water on the door does not?
  • 79 Answers
SOURCE: kenmore refrigerator side by side model
Your fridge has a dual solenoid water valve - one side controls the water flow to the dispenser, the other to the ice maker. It's possible that one side burned out while the other is still good.
Here's a photo of what it looks like:
Here's a link to the replacement part:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/218658000/0046/253/Model-25358682890/0582/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=25358682890&subCompDesc=Icemaker&brandDesc=KENMORE&modelDesc=Side-by-Side&blt=11
Before replacing the part, make sure the solenoid is in fact, bad. Get a voltmeter, and touch the probes to the electrical contacts on the solenoid, like so:
If the meter barely moves, the solenoid is bad.
If both solenoids test out OK, the other possibility is that the water supply line is kinked or clogged. Also, if your water dispenser has a filter (also on the back of the fridge), it might be clogged. My money's on the solenoid, though.
Good luck, and if this helps, please my answer!
Also, thanks to Zenzoidman for the pics.
Posted on Feb 01, 2011
Testimonial: "I've got someone to fix the problem, but this helps me understand what he might be looking for and what the part will cost. Thank you, Pat"
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
  • 3 Answers
SOURCE: Brand new Kenmore refrigerator, ice maker does not work
According to the manufacture, you must wait 24hrs to reap the benefits of the automatic ice maker. I was helping a friend the other day install a water line to a side by side unit that had been running for well over a week and after turning the water on we got no ice. We contacted the manufacture and they said "there is a 24hr waiting period". This makes no sense. I wasn't trying to get a gun permit, just ice.
Posted on Jan 13, 2009
I have a Kenmore model number 106.51552104 my ice maker stopped making ice.. The water on the door still works but no ice what should I do??
I believe I answered this one on another page of unsolved problems HERE. Thanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in the slots and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore refrigerator stopped making ice. in door water still works model 106.5779*703 Ice maker is on, door bin is clean
make sure the unit is on and the flag is in work position.
if tis not help you might need to replace the ice maker unit which go for 120-150$
Dec 28, 2009 | Kenmore Refrigerators
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice Maker does not work.
Check the line going to the ice maker for clogging.
Sep 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not working, water not going in tray.
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
