Question about LG MV1604ST 1000 Watts Microwave Oven
I have a MV1604ST over the range microwave oven. After I made my daughter's breakfast this morning, the fan kicked on and will not shut off. It has been running for hours. The microwave still works and heats. The instruction manual says this can happen if the temperature gets too hot around the oven, but could run for up to an hour. There is no mention of over 6 hours. Any suggestions?
    Sergeant:
  • 260 Answers
There si a sensor on the bottom of those Micros that is supposed to turn the fan on when it closes, meaning it is hot, then opening when it cools back down. I expect you have a bad thermal sensor. I have very seldom found these to go bad. Another thing that can cause it is a bad door switch back feeding voltage where it is not supposed to. It will make the fan that cools the magnetron run until the bad switch is replaced.
Posted on Aug 16, 2017
  • 833 Answers
SOURCE: Fan is always on when microwave is working
All microwaves have an internal fan. Generally, they work whenever the unit is heating. There may be a second 'overload' fan...that may be what they are referring to. If this is an over-range unit, these items have special sensors related to heat from the stove. My advice: don't mess with it if it is doing whatever else you want.
Posted on Dec 19, 2007
  • 96 Answers
SOURCE: Replacing the lamp in the microwave of a Kitchenaid KEMC378KSS01
Have work on these model, but narmaly they should be easy, to help, unplug it and open the cover to see if you can figure it out better, narmaly it's a clip on stage plastic that hold it in place, The bult could have purchse I think true gooles, with there part # back track it to see if a local shop would have it. $30 was very high.
I hope this help
What About Bob
Posted on Feb 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
ginko
  • 19396 Answers
SOURCE: lrm1250w/01 lg microwave turns on and runs but
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Jun 02, 2009
SOURCE: my microwave runs but it does not get hot ,t stop doesn't work
I had a similar prob with another brand microwave. It is a defect and they recommended stop using it. Since mine was out of warranty, there was nothing they would do. That night, it came on by itself for the last time with a grand finale of grand finale's firework show. I had to jump on top of the fridge to unplug it. Totally freaked me out. Hint: don't buy cheap $49.00 microwaves. Spend some money and buy a good one or you might be homeless after your house burns down.
Posted on Jun 11, 2009
Cannot turn microwave off. Help
Only happens when cooking a big pot under the microwave? Hosing thermal fuse / thermostat kicks in to cool the microwave. Is the micro. Installed proper height above the range? Are you using the fan when cooking on the range?
Apr 30, 2016 | LG Microwave Ovens
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
My fan kicked on by itself and won't shut off
The over the range microwave hood has a heat sensor in it. If it senses hot temperatures from cooking below it will turn the fan on. The fan will turn off once it cools down, this is to protect the microwave controls from damage.
May 08, 2010 | Magic Chef CMV1100 Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
Whirlpool microwave, intermittent blower activity, shuts down microwave
Not clear what to explain but would look at the front control switches, commond problem, to see just play with the door open and closing to see what happen's with the fan, it's probroly not making proper contact, the other problem I can thing of is bad thermal heat sensor, there should be two or three of them, you need to know the basic what they do to test them just jump them, and try the unit and see if the problem stop to see witch termal is deffective.
Hope this help
Bob The builder
Feb 07, 2008 | Microwave Ovens
Microwave Fan won't shut off, no display
Depending on which brand you have I would think that the Thermal switch on top of the magnetron or one of the door switches has probably given up the ghost. However, if the display does not come on you probably have a micro or Psu fault on the display panel. Not to be attempted if you are not familiar with microwaves or electronics. Please unplug before opening. Good Luck, JUS004
Jan 05, 2008 | Microwave Ovens
LG MV1604ST 1000 Watts Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
