Question about Toshiba A505S6005 Core i3330M DualCore 213GHz 4GB 500GB DVD RW DL 16'' Win7 Home Premium wWebca (PSAT6U005002B) PC Notebook
I've got a Satellite A505-S6005 and I've been happy with it so far, except that I noticed yesterday that my touchpad mute button will no longer work. The noise is still made when I hit the button,and the light flickers on and off, but the computer does not respond to it. Today I noticed that I can no longer turn off my mouse wiht the button that is just above the mouse pad. Now I am forced to FN 9 to turn my mouse on and off. Has anyone else experienced this problem, or have a solution to this problem? All of my other touch pad buttons are functioning just
  • 113 Answers
SOURCE: frozen mouse with a touch pad laptop computer
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
Posted on Jan 26, 2008
SOURCE: Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Posted on Aug 02, 2008
  • 2404 Answers
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Posted on Jun 27, 2009
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Posted on Jul 08, 2009
  • 566 Answers
SOURCE: Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Posted on Aug 17, 2009
Volume control not working or opening
Audio module may be bad, it can be replaced. Use Control Panel Device Manager and delete the audio module to see if operating system will see it and reload driver upon reboot.
Feb 02, 2013 | Toshiba Satellite A505-S6005 (4400 mAh)
Toshiba SAT A505-S6005 Power cord was plugged when laptop fell to the floor and hit where the cord attaches to the receptical (on computer) which jammed (pushed) the thin connector prong further into
When this happens it means that the whole recepticle has been broken off of the motherboard and the whole laptop will have to be disassembled. This is not an easy job for someone who hasn't done one before. After it's disassembled it has to be determined if the recepticle can be resoldered or not. Sometimes the damage is not repairable. Good luck!
Nov 22, 2012 | Toshiba Computers & Internet
USB ports not working
jst see control panel usb setting or ur power scheme setings
Mar 23, 2012 | Toshiba Satellite A505 Notebook
How can I download web cam of satellite A505-S6005 Toshiba
You can download theWEBcam and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: -
Aug 09, 2011 | Computers & Internet
Toshiba satellite A505 S6005 webcam driver. the system could not locate it.
Head over to Toshiba's support site for your laptop here. Switch All Categories to Camera and download the web camera application. This contains the web cam driver.
Feb 28, 2011 | Computers & Internet
HI, I need the procedure for replacing the screen on my Toshiba a505-s6005. The screen size is 16" Thanks to anyone who can help.
Turn the computer off.
Disconnect the AC power.
Then, since you need to ask "how" to do it, I strongly recommend that you take the computer to a qualified technician, for _professional_ repair.
What you're wanting to do is _very_ complicated, and you could really "break" things, as you try to disassemble your computer, without breaking any wires that connect the motherboard to the LCD screen.
Sep 20, 2010 | Toshiba Satellite Laptop with Intel Core...
Is the Toshiba A505 s6005 capable of burning a
  • Multiformat DVD±RW/CD-RW drive with double-layer support
    Records up to 8.5GB of data or 4 hours of video using compatible media; also supports DVD-RAM and Labelflash direct-disc labels using compatible Labelflash media.
  • I would say is the best optical unit around talking about a dvd and not blue-ray if you insert the right kinda disk it has the ability to burn the 8.5 G dvd'es (DVD+R)
May 27, 2010 | Computers & Internet
How do you highlight with a touchpad
With most touchpads you hold down the left mouse button to select then move the cursor with the other hand by pressing a finger on the touchpad and dragging it. Be sure your touch pad is not disabled - usually a button near it with an indicator LED.
Dec 12, 2009 | Toshiba Satellite A505-S6970 Notebook
Loud Beep on media control panels volume buttons.
I had the same problem. They sure make it tough for you, don't they? Urgh... it was annoying. Anyway, this is what fixed it for me, a solution from another site:
In the control panel, under sounds. Go to the speaker properties, and then the levels tab and mute the computer beep level.
Jul 04, 2009 | Computers & Internet
Toshiba A505S6005 Core i3330M DualCore 213GHz 4GB 500GB DVD RW DL 16'' Win7 Home Premium wWebca (PSAT6U005002B) PC Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
