Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony KDL-40V4100 when turned off will go into standby. Red light is solid. Orange also on, but blinks aprox every 15 sec. If power is disconnected overnight set will turn on and stay on. If set top box (ATT Uverse) is turned off TV will go into standby and not come out untill power is disconnected overnight.
  • 5 more comments
  • wmroos Mar 25, 2011
    The red "standby" light does not blink. It is on solid.
    The orange (amber) "pic off/timer" is solid for about 15 seconds then it blinks off and comes back on for about 15 seconds. This happens over and over again.
  • wmroos Mar 26, 2011
    did the Display-> Channel 5 button->Volume -(volume down). No code came up, only the volume indicator
    002 power
    002 power
    002 power
    002 power
    002, 003, 005, 006, 013 are all 000. under that is:
    00172 00136 00172 00000
  • 4,889 Answers
Can you please count the number of blinks in between each pause so that I can tell you what the problem is? Its a self-diagnostic error code that makes the diagnosis a lot easier
Posted on Mar 25, 2011
  • 2 more comments
  • eagle338
    eagle338 Mar 25, 2011
    That sounds like a power supply board issue. Anyways try this to confirm. Press on the remote the following buttons in rapid succession. Display-> Channel 5 button->Volume -(volume down) and power button in rapid succession. A small box should appear on the tv indicating some numeric values like 002 etc., Try it and tell me what you see(If anything)
  • eagle338
    eagle338 Mar 26, 2011
    Display-> Channel 5 button->Volume -(volume down) and POWER. You have to press all 4 in quick succession(with in 1 second of each other) to get the code.
  • eagle338
    That confirms my suspicions about the power board. You will have to replace it to resolve the problem. Please get me the part number off it so that I can find you a replacement. It will be something like A-xxx-xxx-xxx
    Also please do not send so many comments in rapid succession. I just left to have my dinner
  • eagle338
    You should remove the back cover to get to it. Power supply board is the one into which the power cord plugs in
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Red flashes 6 times and pause for three secs
Using the remote, open the system menu and reset the tv.
Mar 07, 2015 | Sony Bravia Kdl-55ex500 55 Tv, Series Lcd...
Sony bravia blink red lamp 5 time
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Gopakumar Gopalan Google
Feb 23, 2014 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony bravia kdl-40v4100 . The standby light is flashing red 2 times an television and there is no picture or sound . Relay dls1u an power supply board is clicking on/off .
Two blinks denotes an over-current protection. If you wish to get more details about the blinking codes to Sony TVs, check this site. Details are there. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 19, 2013 | Sony BRAVIA KDL-40V3000 Television
Red standby light go on when I turn on mt Sony bravia
set should have a blink or error code of some type if set does not work--count red and or any other lights blink sequence---3 blinks, 5 blinks etc.
May 14, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Standby mode
Standby power supply runs 7/24 and this should indicate it is not allowing main power supply and hence the set to turn on= short someplace is most likely issue.
Does red light blink and in a sequence of blinks?
Apr 23, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
May 08, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
340 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
