Question about Acer Aspire 5742Z-4200 Notebook
Acer 5472z laptop up arrow key popped off (not the number one) and I cannot find instructions on how to fix. When I pop back on one side stays raised. Online instructions are for regular sized keys with different hinges. Could use diagrams
  • 112 Answers
You have to make sure you put the hinge back together correctly if it popped off. Lay the hinge in place, then put the key on top if it, and give it a good solid press.
Posted on Mar 25, 2011
  • 734 Answers
Hi There,
I've never replaced an Acer arrow key before (although zillions of other keys). You may just want to get a new keyboard. Here's a link to the only listing for one on eBay.
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1313&_nkw=Aspire+5742Z-4200+keyboard&_sacat=See-All-Categories
Regards,
Selk
How to activate touchpad on acer e1-571
Hi
One of the toggle switches using the FN key turns the touchpad on and off.
<Fn> + <F7> Touchpad toggle. Turns the built-in touchpad on
and off.
If you go here :-
Drivers and Manuals
and selecting your model from the selections offered ie "Notebook" then "Aspire" then "Aspire E1-571" you can find all the documentation, drivers, applications, BIOS etc for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 16, 2014 | Acer Aspire Computers & Internet
I tried safe mode and normal but it don't work the mouse Icon just stays There the login screen never pops up. Pleas help
You need to get back into the BIOS to see what is going on. As the machine boots up you need to hold down the key or keys that you see pop up quickly on the screen instructions...
Jan 15, 2013 | Computers & Internet
How do I pop my keys back on? My 2 year old popped them off now I can't seem to figure out how to pop them back on.
I have had an Acer Laptop for a long time now and this is one of the things that i dislike about it.
i had popped my space bar off to try and clean underneath it and was never able to get it to fit back on properly. the best thing it to try and apply even pressure around the whole key while pushing it where it belongs.
Aug 21, 2011 | Acer AS5552-6838 15.6-Inch Laptop (Mesh...
The right arrow key has popped off.it has 2 clips on it.How do they go back on?Thank You
As long as the parts didn't break, you can just carefully line it up and press down until it clicks back into place.
Jul 01, 2011 | Acer Computers & Internet
How do you fix the keys from sticking, due to something spilled on keyboard?
You will have to pop the keys out and use a damp cloth to clean it. look for manufacture cleaning instructions or very gently pop the keys out with a butter knife or flat head screw driver.
Jul 26, 2010 | Acer eMachines E7254520 Notebook PC
How do I pop a key back on my keyboard acer aspire one netbook; popped off and can't get it back on.
There's a small plastic spring type clip that fits under the key. It has little nubs that stick out the side and fit into slots on the keypad base. The nubs break and your lucky if you find a replacement that stays in place long. You can get a new keypad for about 40 bucks on ebay and replace it in about 10 minutes.
There's a plastic trim strip across the top. pop one side with a small flat screw driver, remove, 2 screws at the top of the keypad and a ribbon cable to the motherboard. When removing the ribbon cable there's a small lip at the top of the connector, carefully lift that lip and the ribbon will pop out. Have fun
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
The t key popped off of my acer 5420...does not look broken. How do you click them back in
You just have to click it back in, simple as that.. Use a little force, and then it should stay on the keyboard. Just don't use TOO much force :p
Sep 09, 2009 | Acer Computers & Internet
Some keys of my compaq M2000 dont function
Here's the FULL service manual.
http://h10032.www1.hp.com/ctg/Manual/c00312740.pdf
Hope this helps.
Please don't forget to rate my solution FixYa
Thanks!
Mar 02, 2009 | Compaq Presario M2000 Notebook
My laptop wont turn on!
Reboot the battery tapping the F8 key... when the menu pops up use your up and down keys to select last known good configuration.... boot to that... that should fix it up.
Robert
Please take a moment to rate this solution thanks
Jan 26, 2009 | Acer TravelMate 529ATX Notebook
Acer Laptop - key topped popped off
Yes it does snap back on. Place it where it on top of the retainer and press down gently until it snaps into place. You may need to work it around a bit in order to line it up. If it doesn't snap on or doesn't stay, check the bottom of the key to make sure the sides where the retainer goes into hasn't collapsed, or check the retainer to see if one of the pins that snaps into the key isn't bent or broken. If the sides are collapsed or a pin is bent, you can bend the side or pin back into place with a small screwdriver, be gentle as not to break it. If it's broken it will need to be replaced.
Jul 16, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5742Z-4200 Notebook Logo
1,589 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
