Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
My 23 hp kohler courage engine starts and runs for several seconds and stops. The gas is fresh, new plugs.gas filter. Fuel pump is working.The thing ran fine two weeks ago. Thanks, Mike
    Sergeant:
  • 259 Answers
It sounds like the jet is dirty in the carburetor. Remove the float bowl and in the center there should be a jet that you can remove and clean. There are small holes on the side of it which you can clean with a thin piece of wire. Clean the center hole also.
Posted on Mar 25, 2011
Engine starts and only runs for about 3 seconds. The only thing I did was replace the battery with same kind. Filter has been replaced, fuel lines not clogged?
sounds like a fuel problem. im guessing a fuel filter or possibly the carburetor is clogged. you may need to take the carburetor off and clean it real good . put a new needle and seat in it. they are cheap. there are many videos to show you how to do this on you tube. good luck
Mar 30, 2016 | Cub Cadet Riding Lawn Mower. 42 in. 22 HP...
Won't start. In storageempty18 mths. Replaced oil,filter, fuel filter,spark plug, New battery. Fresh gas w/stblzr. Engine cranks but won't turn over.
Won't start. In storage empty18 mths. Replaced oil, filter, fuel filter, spark plug, New battery. Fresh gas w/stblzr. Engine cranks but won't turn over.
Without the exact engine model, I am not sure which Kohler 19 HP you have. There are different models including single cylinder with fuel pump, single cylinder without fuel pump, and multiple versions of the twin cylinder. Therefore, some parts of this answer include generalizations which may or may not be applicable.
Sooo, with the new battery the starter motor does crank the engine; the engine turns over. This informs us that the engine/bearings, has or have, not frozen up while in storage. However, I believe you are indicating that the engine does not fire up and begin running; it won't start and it won't run.
We know the machine has been in storage 18 months. Was the machine completely emptied of fuel, tank and carburetor, prior to long term storage? That is the question of the day.
I am going to assume the machine was running fine the last time it was used; prior to parking it in storage. That means we are assuming there are no mechanical problems with the engine. I am going to assume, with the installation of new plugs, you checked for spark and all is good in that area. This really leaves us with a fuel system problem.
A mechanically functional (meaning all the internal parts are working, i.e. pistons, valves, etc) engine requires 3 things all at the right time, air under pressure (yes they call that compression), fuel, spark. So the quickest way to start your diagnostics is to remove the cover over the air filter and then remove the air filter. I do not recommend spraying Quick Start.
  1. remove air filter (set it aside for the rest of the diagnostics)
  2. put throttle on fast run (do not choke)
  3. pour an ounce or two (a shot glass, not ½ a beer) of fresh gas into the carburetor
  4. crank engine (15 to 20 seconds, rest to cool the starter, repeat 3-4 times if it does not fire at first).
Removing the air filter and placing the throttle at full speed, with no choke, eliminates the "air intake" question for now. Dumping in the fuel bypasses the fuel related question.
  • ·If the engine fires and runs a bit, then dies, you may have eliminated the spark question and you need to track down any fuel problems.
  • ·If the engine does not fire you likely must tract down a Spark problem.
I understand that you filled the tank with fresh fuel.That is step one, of 7-10 possible steps for getting fuel to the engine. Which brings us tooo..
  • Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling. Was your tank clean and dry?
  2. Is there a cut off valve at the gas tank? If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look ¾ full of fuel. If it's not that's a clue to fuel flow problems.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
    Do yourself a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank. Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started. I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger. Once you have a good fuel flow out the line to the filter, reinstall your FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  4. Check the fuel pump. The fuel pump system on the twin Koehler and the Twin Briggs are almost identical. This includes most single cylinder engines with fuel pumps. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. . https://www.youtube.com/watch?v=HAUZUPoopSI
  5. Note: My engine was starting hard and dying in the field this year (March 2015). While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump. It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  6. Note: If your engine has a vacuum operated fuel pump it requires crankcase vacuum to drive it. A Reed Valve creates this vacuum. If your reed valve is stuck, broken, or just worn out you will not have a functional fuel pump; even if you buy a new one. If your fuel pump is not working, you must verify crankcase vacuum before buying a new pump.
  7. Most, if not all, fuel systems now have a Fuel Shut Off Solenoid. This is a small cylinder on the bottom of the carburetor (with two wires running to it). The fuel shut off solenoid's main function is to stop fuel from flowing into the carburetor. It does this for various reasons
  • You turn the key off.
  • You put the mower in reverse while the blades are turning.
  • You blow the main fuse due to electrical malfunctions.
Diagnosing the Fuel Shut Off valve:
  • Assuming the battery is good and fully charged
  • Assuming the Key Switch is working.
When you sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. If you hear this click your fuel solenoid is functioning electronically. It could still be experiencing issues inside the carburetor. Perhaps there is some varnish, silt or other trash keeping it from working. If this solenoid is not working, you will get no fuel into the carburetor, even if the pump is working. This will require a physical examination of the solenoid and perhaps the entire carburetor.
The following is an "out of carburetor" electrical check up.
  1. Remove the Solenoid.
  2. Connect one jumper wire from a terminal to the positive battery post.
  3. Connect a second wire from a terminal to the negative battery post. The solenoid should retract.
  4. Remove one jumper; the solenoid should spring back out.
If none of this solves your fuel problem you may have to remove and disassemble, clean, soak overnight in carb cleaner, or rebuild the carburetor at this point. You may have water, dried fuel (varnish) or trash in the carburetor bowl or jets. Before removing and disassembling the carburetor try draining the bowl. Or, take the bowl off, careful not to drop the small parts inside. Clean the bowl and replace. I often remove the bowl on small engines and find all kinds of built up gunk. This saves the hassle of a complete carb removal, sometimes.
What else could make the Fuel Cut Off malfunction??
Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info (exact engine model) and I will walk you through the next step. Tracking down a spark problem; yes, your problem could involve the coil, coil wire and spark plug.
Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
Apr 19, 2015 | Ariens 42 in. 19 HP Kohler Hydrostatic...
Partial loss of power
It could be a short in the magnito a dirty carb prob. Or foul plug also use fresh gas to narrow the broblem. I almost forgot check the compression.
Jun 21, 2013 | Craftsman Kohler Courage 26 hp 54" Garden...
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
Kohler k582 runs poorly at operating speed. ok at idle. ambient temperature is 30 degrees.carb main fuel needle adjustment is ineffective. backfires with occasional black smoke. condition started as...
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
Jan 13, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
1,042 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
