Drivers wont install for a compaq presario ,model:CQ5700Y(for a serial to usb cable converter)
SOURCE: audio driver compaq presario c707tu for windows xp
have formatted my PC..and now i cant play any audio files.i need an audio driver for LENOVO 3000 H SERIES desktop board..i downloaded realtek.it did not work
Posted on Feb 27, 2008
  • 4 Answers
SOURCE: compaq coa presario v2000 lost driver
most of the drivers are picked up by xp.....the audio driver although an AC97 you need to download an older version of the driver realtek ac97 3.97 usually does the trick.....install it and then uninstall the driver from your driver properties and then click 'check for new hardware' button. When it asks you to connect to the internet let it do this.....it will then install a driver which works called conexant ac-audio link.....this one works.
The xpress 200m driver you can get directly from ati
Posted on Oct 20, 2008
SOURCE: please help me download the audio driver for hp compaq presario
Please use this link to solve ur problem..
http://hapapism.blogspot.com/2008_04_01_archive.html
Posted on Mar 02, 2009
  • 65 Answers
SOURCE: How cac I get the UAAHD audio bus driver for COMPAQ PRESARIO
I do not know if this is an actual card or is it a software program? IF it is a piece of hardware like a bus CARD then I find that www.download.com (or www.downloadS.com has a GREAT selection of Drivers.. to set up an account is free and once you set up your account you can search for any specific drivers OR goto the site that represents your audio device and look under support or even talk to a tech you should be able to find the driver you are looking for at any of hundreds of sites
Posted on May 22, 2009
SOURCE: Laptop - Compaq presario C771 TU - Graphic, Sound Drivers
i am lokendra kumar
i want to download sound driver
presairo c791tu
plz tall me my Email-id is
lokendrakumar2009@gmail.com
Posted on Jan 01, 2010
How do i remove the powerr supply from a compaq cq5700y desktop?
Unless this one is different than the other ones I've worked on there are 4 screws in the back of the case that hold the power supply in remove those screws and it should come right out unless it has other brackets helping hold it in
Oct 07, 2014 | Compaq Presario Desktop / AMD Athlon II...
Hi i am useing compaq presario cq60 205ee webcam diver
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Jun 02, 2012 | HP Computers & Internet
Compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
Feb 23, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Need help with Compaq Presario v2000 drivers
Your DVD drive is missing the Burning Program not the driver. I found an update for your windvd software for windows 7 but you probably have to have the full program installed to run the update. Hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432985&prodNameId=500746&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ob-26952-1
Jan 10, 2010 | HP Compaq Presario V2000 Notebook
Com.port failed
Download and install the latest proper driver for the TU-S9 cable.
Also, are yo sure that this mysterious "external serial device" is working properly, or is even compatible with the computer?
Last but not least, you could buy and install a PCI serial port card...
http://astore.amazon.com/dellebizcompu-20/detail/B000EDPY86
Mar 23, 2009 | Dell Dimension 2400 PC Desktop
Compaq Presario V2000 Audio Drivers
hi ashok, it's a major problem with the Compaq laptops...
as they donot provide display & audio drivers with the system!
you should search the drivers on google search using ur Model no. !
Dec 26, 2008 | HP Compaq Presario V2000 Notebook
Sound Driver of a Compaq Presario C700 Notebook PC
I am facing problem of Sound Driver. I am also using Compaq Presario C700. Thank you for sorting out my problem.
http://www.joomladesignservices.com/684-going-mobile-with-your-joomla-cms-portal.html
Nov 20, 2008 | Audio Players & Recorders
Driver probs
Here's a link where you can download the drivers for your presario v3000 laptop.
Compaq Presario V3000 CTO
Nov 06, 2008 | Compaq Presario Notebook
Gps
Hi fire1961,
Downloading data from my FURUNO GP-30 gave me no problems. But it took me long time to figure out why I coudn't upload waypoints and routes to the GP-30 via the serial port in my ThinkPad T30.
I tried nearly everything tested the cable, tested a lot of different software and even wrote a little c-program to communicate with the serial port. I also tried a serial-to-usb converter with no results. Then I stumbled over this RS232 Tutorial. According to this - serial ports are not just serial port but can be divided into three general categories:
The types of driver ICs used in serial ports can be divided into three general categories:
* Drivers which require plus (+) and minus (-) voltage power supplies such as the 1488 series of interface integrated circuits. (Most desktop and tower PCs use this type of driver.)
* Low power drivers which require one +5 volt power supply. This type of driver has an internal charge pump for voltage conversion. (Many industrial microprocessor controls use this type of driver.)
* Low voltage (3.3 v) and low power drivers which meet the EIA-562 Standard. (Used on notebooks and laptops.)
Then I installed the waypoint upload software to my ten years old Compaq Presario and suddenly I could upload routes and waypoints but only via the on board serial port. The serial-to-usb converter didn't still work.
So if people experience no result trying to upload data to these old GP-30's from their notebooks and laptops. Then I think it could be a matter of these Low voltage ports not are able to provide the FURUNO device with enough voltage. See the above RS232 Tutorial.
Best Regards
Lars Erting
Aug 03, 2008 | Furuno GP31 GPS Receiver
Compaq presario m2000 sound card
logon to compaq website search for your model and download sound drivers
Jul 15, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
