Question about KitchenAid K45SS Classic Stand Mixer
I have a kitchaid mixer that is pulsating at low speeds?
4 Suggested Answers
hslincoln
  • 235 Answers
SOURCE: Question regarding KitchAid mixer, Model K45ss. excessive noise.
Maeveda, Congratulations on your 30 year old KA mixer! Was it a wedding present? Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
Good luck and have fun. I hope this helps. Howard, Burke, VA
Posted on Nov 04, 2009
  • 143 Answers
Yes this indeed does sound like you have a problem. There could be a couple different cause of this noise. If your main drive or worm gear has been damaged, it is likely to not run at all or jam up. So i think this is not the problem. There is however a codder pin located inside the transmission gears this can be seen by removing the upper housing of the unit, and then exposing the oil and gears. clear away the oil surrounding the gears, and save this grease for later. After this you should be able to visually see this codder pin AND the gears, rotate the gears while inspecting them and the pin. If the pin is slightly bent or broken this will make the grinding noise that your are talking about, while still operating and driving the unit. part number for the codder pin is 9705444. If however the noise is coming from the motor area this could indicate a worn or faulty motor bearing. This can cause the motor to operate on an angle and can cause a rubbing noise from the cooling fan or the winding of the motor itself rubbing on the mixer housing. Part number for the braket and bearing is 3180526. both are relatively cheap and easy to replace. If you find and fix the problem be sure to inspect or change the oil as this can often have metal chunks and other particles. Hope this Helps
Thanks
Posted on Nov 06, 2009
SOURCE: mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Posted on Jan 24, 2010
Knob for kitchaid stand mixer
I am assuming you mean the little black knob on the speed control has broken off. I will post the solution for that problem.
The speed control lever on KitchenAid mixers has a little black knob on the end (in some cases this may be white or gray). The knob is pressed onto the lever, so if the knob breaks off your only option is to replace the whole lever.
KitchenAid has a kit that will include all you need to replace the speed control lever. It even comes with instructions. Here is a link to the speed control lever kit on our website: http://www.mendingshed.com/kaleverkit.html
The lever kit includes the speed control lever (with knob), speed link, spring, instructions and a gearbox gasket.
The instructions will only walk you through how to hook up the speed control lever, so if you also need a little guidance in taking the mixer apart, and reassembling it please use the KitchenAid service manual. The manual will walk you through all of the repairs you may need on your mixer, including how to take the mixer apart and put it back together. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Remember, The Mending Shed is a Authorized KitchenAid service center, we can help you with any repair needs for your KitchenAid appliances, plus all of the parts we carry are genuine KitchenAid brand.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 15, 2013 | KitchenAid K45SS Classic Stand Mixer
I just got a kitchAid standmixer today and I'm sooo happy,but when I turned it on i noticed a little spark going out from where i should change the speed ,, is that normal or do I have to return i
You are probably seeing some dust or the brushes wearing in, unless you smell something burning, its may be just breaking issues. Any electric motor will have small sparks at the brushes. Are they sort of behind the round brush replacement screws?
Jun 30, 2012 | KitchenAid Food Mixers
Mixer works on high speed but not low. Brushes
Jan 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Nov 02, 2009 | KitchenAid K45SS Classic Stand Mixer
Question regarding KitchAid mixer, Model K45ss. The vertical mixer shaft has play in the gearbox, it makes worn gear noises at all speeds. I adjusted the speed control to manual specs, the speed control...
Thanks
Kitchenaid artisan mixer does not turn the blade at low speeds
If it is the worm gear then the planetary will stop turning when there is a load on the paddle but the motor will continue to run at the speed you set it at. I'd be checking the carbon brushes, checking that the field assembly has not loosened up a bit and then I would see if the speed control plate adjustment screws are loose. I'd then reset the speed and see if it stays as it should be.
Sep 24, 2017 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer
It sounds like it is the Control Switch. call up KitchAid and tell them what happened. Seems to be a common problem with them.
Jan 15, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchaid 300
Hi Have nice day
At the link below you can find usefull informations and step by step instructions to repair it.
http://home.howstuffworks.com/how-to-repair-small-appliances4.htm
does it help?
Jan 10, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
187 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
