Question about Lexmark Prevail Pro705 Wireless All-In-One InkJet Printer
After printing a few pages the printhead carriage stalls. this is a new printer installed a week ago.
  • 39 Answers
Make sure you took all the packaging things out.
Posted on Mar 25, 2011
How do you replace ask2000 printhead
Normally you can follow these given steps..It can be different for different model.....
Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place.
The print carriage will move to the center of the unit. After the print carriage stops, release the gray print carriage latch and lift upward to access the printheads.
Remove the old printhead by lifting the printhead handle and pulling upward.
Being careful to touch only the black plastic remove the new printhead from the packaging and gently remove the plastic tape.
Using the printhead handle, push the new printhead firmly down into the appropriate slot; matching the color on the top of the printhead to the color on the printhead carriage.
Move the print carriage latch down, and make sure the loops catch the hooks. Snap the latch into place, and close the print carriage access door.
After the message to align the printheads appears in the front panel display, press Enter . A page prints to confirm alignment.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 06, 2012 | FUJIFILM Ask2000 Thermal Photo Printer
Replace print heads. How?
REPLACING HP PRINTER, PRINTHEADS
Follow these steps to replace the printheads in your printer.
  1. Press the Power button (c00636182.gif ) to turn on the printer.
  2. Open the top cover.
  3. Press and hold the Resume button (c01219285.bmp ) until the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left side of the printer. If the carriage does not move to the left automatically, turn the printer off and back on and then try holding down the Resume button (c01219285.bmp ) again. The printhead can be damaged if the carriage is not all the way to the left for installation.
  4. Lift the printhead latch. Figure 3: Lifting the printhead latchc01290070.gif
  5. Lift the handle of a printhead and use it to pull the printhead out of its slot. Figure 4: Removing the old printheadc01295543.gif
  6. Shake the new printhead at least six times while the printhead is still in its packaging. Figure 5: Shaking the new printheadc01134519.gif
  7. Remove the new printhead from its package, and then remove its orange protective caps. Figure 6: Removing the protective capsc01134520.gif CAUTION: Do not shake the printheads after removing the orange protective caps.
  8. Insert the printhead into its color-coded slot (the label on the printhead must match the label on the printhead latch). Press down firmly on the printhead until it snaps into place. Figure 7: Inserting the new printheadc01290071.gif
  9. Pull the printhead latch all the way forward, and then press down until the latch engages. Figure 8: Closing the printhead latchc01290072.gif
  10. Close the cover. Figure 9: Closing the coverc01290073.gif
  11. The printer should align the printheads automatically in a few minutes, printing an alignment page. If it does not, go to the next section to align manually.
Align the printheadsIf you installed the HP software, use the instructions in the left column below. If you installed a Plug and Play driver or other driver, use the instructions in the right column.
Mar 05, 2010 | HP Office Equipment & Supplies
Just took my old hp deskjet 932c out of the garage.
What many people do not realize is that an ink cartridge and printhead must be used on a regular basis to function properly. Recommendation is a few pages each week. If not, the liquid ink will dry and block the nozzles. First course of action is to purchase new ink cartridges. If this does not work, than purchase new printheads. However, it would be less expensive in the long run to just buy a new ink printer with the cost of ink printers being as low as they are.
Popular Mechanics did an article on this very subject a few years ago and there is a software program on the market that will automatically print a page or two every week to prevent this problem.
Mar 14, 2009 | HP DeskJet 932c InkJet Printer
Wont print
try try again..........
I had this problem;
Printhead replacement instructions are in the users guide.
THIS WORKED FOR ME --AND IF YOU CALL THE TECH SUPPORT # KODAK WILL SEND YOU A REPLACEMENT HEAD........
Power on printer, the printhead rides on a carriage that is connected to the ribbon cable. When the printhead is in the center position and movement is stopped REMOVE THE INK CARRIAGES. DO NOT TOUCH THE INK-PADS OR THE CONNECTION POINTS. You can just place the ink carriages on their side on a clean piece of paper.
......... To separate the printhead from the carriage press the release botton(above the bulls-eye sticker) in the top center of the printhead. You will hear a click and the top of the prinhead will pop forward about 1/4 of an inch. GENTLY lift from back (where you pressed the botton) to front and lift the printhead up and out of the printer.
---------U will see where the printhead and the carriage connect-------
It is best (very important) to not touch the shiny contact area
Now you are ready to install your new printhead.
BE CAREFUL BE GENTLE............Place the new printhead into the carriage and again at the center top back bulls-eye press back until you hear the click and the printhesd is secured in the carriage.......... replace the ink carriages.......
I would power off the printer and wait about 60 seconds then power on and run self test.
TO RUN SELF TEST
power on the printer and wait until the printhead is in the center position THEN press photo and copy buttons at the same time, you will hear the printhead carriage start to move and a test print page will print.
CHECK for print quailty; run all diag. from the help tab as needed.
REMEMBER; IF YOU THINK THE PLASTIC WILL CRACK U ARE PRESSING TOO HARD....... KEEP IT CLEAN, BE SAFE
Jan 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Print quality
CHECK INK LEVELS RUN DIAGS AND IF YOU NEED A NEW PRINTHEAD TRY THIS;
I had this problem;
TO RUN SELF TEST
My printer wony printer after replacing both ink cartridges
I had this problem;
THIS WORKED FOR ME
TO RUN SELF TEST
Jan 01, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
KODAK 5300 WILL NOT PRINT
I had this problem;
TO RUN SELF TEST
Dec 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak easyshare 5300 printer
I had this problem;
TO RUN SELF TEST
Dec 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5100 will not print. Sent an e-mail on 12-25 -08
try try again..........check that the print spoller is on in device setup
I had this problem;
TO RUN SELF TEST
Won't print although it goes through the motions of printing. I have changed the ink and cleaned the printheads
I had this problem;
TO RUN SELF TEST
Lexmark Prevail Pro705 Wireless All-In-One InkJet Printer Logo
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
