Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Kitchen aid ksrx22fnst01 side by side refrigerator having frost allover the inside of the door and ice droppings from the ice maker, I changed the inlet valve but didn't splve the problem, can you help please. thanks. NB.
    Sergeant:
    Champion:
  • 202 Answers
Sounds like you need to get a new door gasket ..if you have frost inside the door
Posted on Mar 25, 2011
No ice forming
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504094
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Water not working but ice does - kitchen aid superba
When you activate the switch, do you hear the inlet valve buzzing? If you do, check the container or tubing in the fresh food side and make sure it is not frozen. If you do not hear the valve buzzing, chech the valve. If it appears to be ok, then you will need to check the switch inside the door control panel.
Please let me know if I can help further.
Thanks
Vic
May 20, 2009 | KitchenAid KSCS25FKSS Side by Side...
I have a Kitchen Aid side by side KSRS25IL. The ice maker after
Sounds like you need to defrost.
if you can move everything out unplug it ,turn it off w/ doors open,you can put pans of hot water in the freezer to speed up the process 12 to 24 hrs this will free up any clogged tubes.After its completely defrosted Only turn it up to 4 or 5. Good luck.
Len West
Feb 27, 2009 | KitchenAid KSRS25IL Side by Side...
Kitchen Aid KSRJC Overheating
There is a heating cable that runs down the door in most fridges it might have a relay that is fussed closed and the heater is always on. I would strongly recommend that you get someone out to look at it as all electrical faults can be quite serious if they are not treated.
A domestic refrigeration tech should be able to fix it for you.
Jan 11, 2009 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
69 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
