Question about Vacuums
How do i replace the needle threader on a jonome DC3050
  • 436 Answers
The operatingmanual is at this link.
http://content.janome.com/documents/File/ManualFile/DC3050.pdf
i hope it helps
thanks
Posted on Mar 25, 2011
Timing after installing new belt
There are about 3 MAIN delicate issues here, could be needle bar, top shaft or bottle shaft, to understand timing first knowing that needle hook is passing the cusp of the needle on its way up....
Feb 25, 2014 | SewShop.com Singer Model 758 Touch & Sew...
Feed dogs don't work!
Many of the older machines had a long geared belt that operated the feed dogs. Turn the machine upside down, take the bottom off and check. If there's a belt there, check it for tautness and for useability. If there is a belt, take it off and try the sewing machine repair shops in Kazoo on S. Westnedge for a replacement.
Oct 23, 2013 | Singer CG590 RBFree$30CarVac*18Stitch...
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
My Babylock Serger Eclipse was bought around 1994 and had a looper threading tool wire to thread it when I could not get it to thread manually. I lost the tool and can't get the thread to blow through....
Try one of the Serger looper threading tools listed on this Amazon.com page: http://www.amazon.com/Serger-Looper-and-Needle-Threader/dp/B000Q30C3G/ref=pd_sbs_ac_1 .
These are third party tools. See the main item and the section "Customers who viewed this item also viewed" for other manufacturer's looper threading tools.
I hope this helps.
Mar 21, 2011 | Vacuums
I can't find a replacement manual for my Janome 8077 sewing machine.
It seems that the Janome 8077 sewing machine and its manual are both out of catalog. A search on all Janome sites around the world only showed a manual for this specific model on the Brazilian site, but unfortunately it is in Portuguese.
Nevertheless, there is a very similar machine (DC3050) and maybe its manual can be useful to you.
In case you would like to check them, here are the links for both versions:
Manual for the DC3050 in English:
http://www.sewingmachinesplus.com/media/products/Janome/dc3050/Inst%20book%20DC3050.pdf
Manual for the 8077 in Portuguese:
http://www.marbor.com.br/v2/webadmin/uploads/manual_8077.pdf
or
http://www.janome.com.br/uploads/geral/produtos_maquinas/manual_instrucao/manual_instrucoes_8077_portugues.pdf
Mar 09, 2011 | Vacuums
Automatic threader is not working
Please repost in correct category with more info.
Mar 07, 2011 | Vacuums
Does this machine have a needle threader and is it 1 step button hole function?
I.U.D.N.V.H.S.E)Is alphabets ko setting kar k1 romantic word banta h,Ye wo bana sakta jisne kisi ko"TRUE LOVE" kiya ho
Feb 23, 2011 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
