Question about Broan-NuTone Heating & Cooling
Need to replace the thermal fuse on the motor on the broan bathroom fan light assembly where can i get a fuse and what kind do i need (which number on the motor is the part #)
    Brigadier General:
  • 4,736 Answers
You can probably get the part directly from Broan-NuTone http://www.broan.com/display/router.asp?CategoryID=511
Hope this helps you find what you need.
Posted on Mar 25, 2011
How do i remove the blower wheel from a broan 684 bath fan
There are a number of YouTube videos that show how to replace the motor assembly on a Broan bath fan. Once you have unplugged the fan and removed the motor mounting plate you will have easy access to replace the blower wheel and/or the motor assembly.
Just go to You Tube and search on Broan
Sep 16, 2014 | Broan-NuTone Dryers
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
Does the motor for a nu tone bathroom fan #86933-000 supposed to have 2 mounting studs opposite the shaft end? 8664RP
Yes. This motor has two studs opposite to the shaft.
Here are some pictures:
http://bit.ly/8YIowa
It is actually a better value to purchase the motor assembly S97017706 or S97017705, both fit.
http://bit.ly/asmjig
Nov 03, 2010 | Broan-NuTone N-8664RP Combination Light...
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
NuTone bathroom fan starts slowly after being off awhile
need to blow it out with a air hose and oil it real good! but keep a eye on it to make sure it does not get hot! if it feels hot to touch replace the motor!
Nov 03, 2009 | Broan-NuTone (668RP) Fan
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Heating & Cooling Logo
1,079 people viewed this question
Top Broan-NuTone Heating & Cooling Experts
Colin Stickland
Colin Stickland
brasseng
Level 1 Expert
Paul Carew
Are you a Broan-NuTone Heating and Cooling Expert? Answer questions, earn points and help others
