Question about Culligan Under Sink Water Filter
Dispenser is leaking. want to know how to disconnect it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
What type of dispenser is it? We need more clarification, information to provide a solution.
RJ
Posted on May 12, 2011
Hsm25gftsa
This problem is common and can be difficult to solve, first of all you have a air leak and because of this, your dispenser leaks. Check every connection for the water system, starting from the back of the unit at the valve. Disconnect the water to the tank first, put the water valve in a bucket and hit the dispenser switch to see if the valve leaks after dispensing water, if it does, replace valve, if not continue in to refer section behind crispers. (this is behind the veggie bins can you see any water at the bottom? If so, repair the leak and continue forward. Check under freezer door at the connection to assure not leaks of water. Again this is a process and after all of this is done or check, one of these solutions should solve your issue. I know not a simple answer but this will correct the issue when everything is checked.
Good Luck
Oct 29, 2013 | Hotpoint (HSM25IFTSA) Side by Side...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
I've moved and when I reconnected my refrigerator the water and ice maker doesn't work. I know there's water to the valve coming out of the floor and I installed a new filter.
Were the doors removed in the move? If so, the electric connection and / or the water line connection for the water dispenser maybe disconnected. Is the filter in correctly? Is there any evidence the refrigerator leaks water? You said you know there is water to the valve, so you disconnected the water line, put the water line in a bucket, turned the water on and you filled the bucket right? You might have a problem with the water valve solenoids for both the ice maker and the water dispenser. Also, check for any kinks in the plastic water lines anywhere.
Nov 04, 2010 | Estate TS22AFXKQ Side by Side Refrigerator
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water has leaked from the bottom of the Washer and now it is flashing F-30?
F30 - DISPENSER SYSTEM ERROR
When the dispenser motor cannot be driven to its proper position.
Possible Causes/Procedure
1.Unplug washer or disconnect power.
2.Check mechanical linkage from dispenser motor to the top of the
dispenser.
3.Check wire harness connections to the dispenser motor and Central
Control Unit (CCU).
4.Check dispenser motor for powered rotations.
May 07, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Leak through drying aid dispenser.can i disconnect it
yes you may have to take off panel to get to dispenser. it has a plug to disconnect
Feb 24, 2010 | Dishwashers
I have a side by side GE refrigerator and the water dispenser is leaking quite a bit. It looks like is leaks where the water is dispensed.
Oct 31, 2009 | GE Profile PSW26P Stainless Steel Side by...
Built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
appliancepartsoutheast@live.com
Aug 10, 2009 | Maytag Refrigerators
Culligan Under Sink Water Filter Logo
60 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Jim London
Jim London
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
