Question about Culligan Under Sink Water Filter
Camachohenry@earthlink.net how to remove a culligan drinking water faucet
    New Friend:
For the newer style faucet:
Use a knife blade to work the rubber grommet at the top of the base upward. This gives access to the cover screw. Remove the cover screw and work the cover up slowly. The small plastic LED window may hold the cover as it has a cable going to it that may tend to stick in the channel below. I pushed the window back a bit to give a little more clearance to free the cover. Just work it up carefully so you don't damage the cable connection. It is potted for strain relief, so shouldn't be a problem. After the top cover is clear you will have access to the secondary cover screws. Remove those and the secondary cover to gain access to the base mounting screws.
Posted on Nov 20, 2012
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
It depends on the style of faucet and how old it is. Their pre 1990 faucets have to be taken apart under the sink. Newer style (plastic, chrome r2d2 faucet) can be taken apart from above. If it is a custom faucet it will have to be taken apart from below sink.
RJ
Posted on May 12, 2011
Culligan reverse osmosis filter system has stopped providing water from the sink mounted faucet attached to the system.
Since unfiltered water went through it for a couple days, I would guess you have mineral build up. If this is the case, be careful about trying to use it. There are certain products you can buy to unclog the pipes. Most will have you pour them down through the pipes connected to the polishing filter. If you can take the pipes apart, I suggest going pipe by pipe to see where the build up is.
Elisa Jed ' http://www.watertectucson.com
Jul 05, 2014 | Culligan Under Sink Water Filter
Trying to connect Culligan drinking water filter to my faucet, BUT, the treads on the faucet are too high for adapters to reach. How can I connect? Also adapters aren't long enough to reach threads....
One thing to try is pick up a tap adapter, from an appliance store. The adapter is intended to connect a portable dishwasher or washing machine....these adapters have several small pieces that may be able to be used with the pieces from the Culligan adapter.
May 01, 2011 | Culligan Home
Our Culligan water system under sink keeps backing up when we use it to get water - we only have this problem when we turn on the Culligan tap to get glass of water.
If you have an air gap faucet and the water is coming out there. The drain, for the RO, is plugged up or the drain line is pinched.
RJ
Jan 18, 2011 | Culligan Under Sink Water Filter
My system vibrates & resonates loudly when the ordinary tap is switched on. Also, water comes out of the filter tap when it isn't turned on, sometimes in a stream, other times constantly dripping. Have...
You are getting water feeding back to the kitchen faucet from the filter system. A check valve needs to be installed on the line feeding the drinking water system to prevent this. Excess pressure may also be causing these problems. An in-line flow restrictor may alleviate the dripping.
RJ
Oct 27, 2010 | Culligan Under Sink Water Filter
A replaced the Culligan 250A filters and now everytime you turn on the water from any faucet in the house you here 2 beeps.
I suggest installing an in-line check valve on the feed line to the Culligan filter and resetting the meter on the filter system. You may be getting water water feeding back out of the filter system when other faucets are run causing the meter alarm.
RJ
Aug 20, 2010 | Culligan Under Sink Water Filter
Two years ago I changed the size of my Culligan holding tank under the sink to a bigger unit and at the same time put in a culligan water softener that also removes chlorine. I also changed the culligan...
hi.
im a plumber and i have seen it meny times befor. relax its calk thats in the water, its harmless and most gps wil tell u iets good for you lol
if it dos freak u out u may wane install a finer vilter sustem
Jul 07, 2010 | Culligan Sales #SY-750S Under Sink Water...
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
Need to remove a culligan faucet
Culligan intentionally designed their faucet so that you have to have a culligan repair man come out. good luck
Jan 18, 2009 | Plumbing
Culligan Under Sink Water Filter Logo
137 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
