Question about Gigabyte GA880GMAUD2H AM3 AMD 880G HDMI SATA 6Gbs USB 30 Micro ATX AMD Motherboard
New build, getting NTLDR Missing message with Windows 7 cd in the CDR and boot sequence set to CDROM.
    Master:
  • 346 Answers
Hello mgarner - Does the system actually try to boot from the CD? You can tell by the LED on the CD drive or you can put your ear next to the drive and hear if it's trying to read the disc.
If it is there are two possible problems, first is that you have a bad drive or secondly that you have a bad disc (the more likely of the two).
See if you can come up with another disc and give it another go.
Thanks for using Fix Ya.
Mikeywaf
Posted on Mar 25, 2011
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
When uploading windows 7 I get a message: Can't load windows at this time because of a hardware configuration problem or I get missing NTLDR how do i fix this?
First make sure there are no Disks in any of the drives CD , Floppy and Usb
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette Test all power and data leads that attach to your hard drive including IDE,SATA if ita flat 40 pin ribbon type it will be the first to fail. The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. b> b>
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
NTLDR missing problem
NTLDR is one of the essential files for booting up your system. If this file is corrupt or missing the computer wont simply boot. The solution here is to Get the CD for your operating system. For example Windows XP or Windows 7 etc. If you are using Windows XP, put the CD in the CD ROM and press Del or F2 to get into the BIOS of the computer. Go to the Boot Order or Boot Sequence and select the CD drive to be the first boot device and press F10 to save and exit. This will allow the XP CD to boot. On the first page after loading all the files, press enter, then you will have to press F8 to accept the Microsoft license, then you can select "R" to repair the system (This will only overwrite the contents in the C:\Windows and this will fix up your start up problem. If you are using Windows 7, boot from the CD like in XP then choose to repair your system.
Feb 22, 2012 | Dell Computers & Internet
NTLDR is missing press any key to restart message appears but cannot get it to restart
DELL Boot error.
  1. You have to go to the BIOS make sure the first, second and third boot device is set to cdrom. Put your startup disk in the CD drive.
    2. once you see a prompt that says press any key to contintue to boot to cd press the Enter Key Once
    3. When you have a prompt that says welcome to windows press R to Repair press F3 to quit and press Enter to create a fresh new copy of windows. we press R
    4. You will be given a dos prompt
    5. Type c:\> cd c:\windows\repair, <Press Enter>
    6. Type c:\windows\repair> del c:\windows\system32\SAM, <Press Enter>
    7. Type c:\windows\repair> copy sam c:\windows\system32\SAM, <Press Enter>
    8. Type Exit
    9. Restart the computer
Jan 03, 2011 | Dell Inspiron 1720 (dncwma1_1) Intel Core...
When i strt my dell latitude d600, powering on there appears" NTLDR is missing", message and below that another message is" Press Ctrl-Alt-Del to restart", but when do so after...
NTLDR is the abbreviation for New Technology Loader. That is a boot sequence for loading Windows 2000,XP, Win 7 etc. It is telling you that the boot file ntldr is missing or corrupt and gives you another chance at loading another system, that is if you have dual booting, however,when you restart the same thing happens. There are many detail specifics about this subject on the internet, so enter the phrase "ntldr is missing" into google and read all about it and how to fix it.
Jan 02, 2011 | Computers & Internet
NTLDR is missing problem
NTLDR is NT Loader program and corrupted or missing NTLDR will not allow you to boot up.
Keep your Operating system Bootable CD ready and boot your computer with CDROM. Follow below instructions to repair NTLDR
1. In Windows XP Setup menu press "R" to repair
2. It will show you windows to login (1. Windows )
press 1 and provide administrator user id and password.
3. one in command prompt you have to copy paste NTLDR file from cdrom to c:\ type the following command
Your cd drive letter you need to figure out. Here I am taking it as d:\
or make sure you below command runs by changing drive letter if not able to determine CD drive letter
Restart the computer and it should work.
Else, again boot from CD ignore Repair option to go in recovery console, and hit enter. It will show you the agreement . Press F8 to accept . Next screen will show you option to repair to continue to fresh installation.
Here press "R" to repair. Not sit back it will take time to repair complete system.
Hope this helps
Jun 10, 2010 | Compaq Armada M700 Notebook
Im getting the ntldr is missing message on my acer aspire 3100 that i just bought from a friend. I have no idea on how to fix this
That is the NT Loader in win98 was boot.ini regardless the OS will not continue without it. You can simply place your OS CD in set your boot order in bios to boot from cdrom. Do a manual windows repair. This will re-install the missing boot loader.
Dec 30, 2009 | Acer Aspire 3100 Notebook
In My PC Error Shows NTDLR File Is Missing,How To
Method:1
1.Make the first boot device as CD-ROM
2.Boot the system with windows(operating system cd)
3.go the first repair(r) option
4.once u got the command prompt change you directory to X:/i386
copy x;/i386/ntldr c:
copy x:/i386/ntdetect.com c:
note:x:(cdrom) drive may change
and then reboot the system.
method 2;
boot with the operating cd and go the second repair option and repair the operating system
Dec 02, 2009 | Gateway 500GR PC Desktop
Ntldr
First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Replace the drive letter listed above for your cdrom's drive letter.
Once copy has been complete re-boot your Pc.
If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Gigabyte GA880GMAUD2H AM3 AMD 880G HDMI SATA 6Gbs USB 30 Micro ATX AMD Motherboard Logo
52 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
