Question about Grundfos JPS4 1 HP Pressure Booster Pump
I have a Grundfos pump type CU 301 that is running constantly 24 hrs a day. The manual switches are not responding at all....i.e. I can not turn it off or change the pressure setting at the box. The only way I can turn it off is to turn off the main power supply.
  • 1 more comment
  • aprilshouse Mar 26, 2011
    Thank-you so much for your prompt response, unfortunately, I am still waiting for one of the men in the family to come help me with this as I don't have the tools or the knowledge of pumps to continue any further. As soon as one of them shows up I will get back to you and let you know how it worked out....lol.
  • aprilshouse Apr 01, 2011
    This model is solid state control. There is no pressure switch, it is controlled by a panel, 24v. controls. The sensor from the water line to the control box is a twisted pair, 24v., The control panel is in "locked" mode, and we can't get it un-locked so we can change the pressure settings on the control panel. Any advise on how to get it out of the "locked" mode? The water is runnng, the pump sounds good, the flow is going somewhere, not into the house, we closed the valve to the house, still keeps running. The pipe down into the well is sched. 80 pvc, and looks good, but have not pulled the pump to inspect all of it. Need to get the control box out of the"locked" mode first.... HELP!!! Thanks. Call 575-895-5631 if you can, Thanks, Dennis Franklin. email dennisb@windstream.net
  • aprilshouse Apr 02, 2011
    Thank-you again! I called my uncle and he is looking up the manual....lol. We live way out in the sticks here so takes awhile. Thank-you for being so patient!
  • Grundfos Master
  • 43,501 Answers
There are two things that can happen to cause this...
First, check that the contacts in the pressure switch are not welded together...sometimes they arc and the heat welds the contacts and keeps the power on...
The other problem is that sometimes dirt or corrosion builds up over the hole where the pressure tubing hooks up to the pump... or the tubing it's self gets plugged with dirt...then the pressure does not change to the pressure switch.. this traps water in the tubing and hold the switch on...
Take the tubing off at the pump, take out the fitting and make sure that the hole is clear...also take off the tubing at the pressure switch and make sure the fitting at the pressure switch is clear and that the tubing is clear...
Make sure to turn off the pump and relieve the pressure first or you may get an unwanted shower!!
Any questions or comments please get back to me...
heatman101
Posted on Mar 25, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Apr 01, 2011
    Okay... sorry I was looking at the JPS4 pum that you had this posted under...
    Here is the manual for the control...
    Page 10 tells you how to unlock by pushing the two arrow buttons at the same time...
    http://www.pumpsandwells.com/miva/Grundf...
    After unlocking, check for alarms, it may tell you what is wrong...
    Also as a side note...
    There have been many problems with these pumps and controls, in fact Grundfos stopped selling them for a time to get them working better...but first make sure that it is not a simple problem that can be fixed easily..
    heatman101
  • D. Floyd Kolb
    D. Floyd Kolb Apr 02, 2011
    No problem...
    I know he left his phone number and email, but FixYa really frowns on us communicating other then through the website...
    Hope he can figure it out for you!!
WHY DOES MY BOILER PUMP CONSTANTLY RUN
Hello anon, this sounds like there is a problem on the electric side of your boiler. Depending on the boiler if its a combi type it is one of the pcb's calling for the pump to run. If at all possible call a specialist who deals with Central Heating and dont try and fix it yourself.
Aug 02, 2014 | Grundfos Pumps Grundfos Redi-Flo2 Electric...
there is usually a pressure switch this may be an indication of the relay switch not opening and closing properly....shut off power then remove the protective cover (usually on top of motor) inspect the relay contacts they may have some burn marks take an emerey cloth or fine sand paper and slide between contacts hope that works
Aug 02, 2014 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
Grundfos runs intermittently and needs power cycle to get going again
What type of pressure switch or pump controller on pump? Could be capacitor check. with power on try spinning fan at rear if starts probably cap. Have it checked. Could be controller faulty.
Jan 27, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I need to reset the timer on my 633T Krystal Clear pump as we have unplugged the power and we can't get the timer to work.
You know the timer can only be programmed once and it is 24 hrs after the last time it ran. So turn it on at the exact time of day you want it to run every day, set the dial to how many hours to run and walk away. It should start up automatically 24 hrs later each and every day (as long as you have the on switch set to the timer position)
Jul 12, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Grundfos JPF4A pump. takes a long time to get up to prime then once it kicks in after running water it gets to 50 shuts of but drop pressure instantaneously and kicks back in again. The constant on off...
The check valve is bad. When the system builds up pressure and shuts off the check valve prevents water from dropping back down the well line. When the check valve goes bad water drops back down the well line and siphons water back out of the well tank causing the switch to kick on and off constantly. The check valve will between on the well line coming from the drop pipe. It may be making a constant rattling noise as pump is running. Replace the check valve and you should be fine. Also check the pressure in bladder tank it should be 2psi below the "cut-in" pressure for the switch.
RJ
May 22, 2011 | Grundfos Plumbing
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
Grundfos Pump Wont Stop Running
Close the outlet valve then turn electrical switch on manual for a few seconds until any air is pushed out then open the valve and return electrical switch to automatic.
Aug 07, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos JPS4  1 HP Pressure Booster Pump  Logo
1,020 people viewed this question
Top Grundfos Plumbing Experts
john h
rayc588
Level 1 Expert
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
