Question about Toro Power Lawn Mower
I have a toro gts walk behind mower. I went to crank it earlier and it cranks and runs about 10 seconds and cuts off. It will not crank. If you prime the engine with the button on the side it will crank again and do the same thing. Is there something that I need to do or what should I replace.
  • Anonymous Mar 30, 2014
    Pull start on a 15hp kohler engine
    Novelist:
  • 111 Answers
This is for the Briggs and Stratton Engine with the square air filter. There could be water in the carburetor. To check to see if you have water in the carburetor you need to loosen the nut on the bottom of the carburetor (it helps to pinch off the fuel line to keep fuel from coming through the carburetor while you do this) and take off the fuel bowl and see what is in the carburetor. Most of the contents of the fuel bowl will drain out but there should be enough left to see if there is water or dirt mixed in with the fuel. When you take off the carburetor fuel bowl check to see if there is any corrosion on the carburetor. This may have a white, chalky appearance or if it is varnish from old fuel it will look like the carburetor has a "gold" appearance. The correct color of the carburetor is a dull or flat grey. If you find water in the carburetor bowl then there is a good chance that there is also some water in the fuel tank. You will need to drain the contents of the fuel tank. If you want to see what the fuel looks like you can drain it into a paint mixing cup or a clear jar. Start with a clean jar or cup, to make sure that you are seeing what is in the fuel and not what was left in the cup. lol. When you have drained the fuel tank and made sure there is no water in it, I would suggest putting fresh fuel back in the unit. See if the unit will start and run ok. If the unit pops or sputters while the engine is running there may be some more water that will come out after the unit is run for a little while. If the unit continues to not run or is not running very well you may have to clean the carburetor. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. When you go to the parts counter you should have the MODEL, TYPE, and CODE off of the flywheel housing. These numbers are stamped into the metal.
Posted on Apr 05, 2011
Transmission went out was wondering how long does it take to take the old one out and put a new one in
for me 30 min. for you could be hours. depends on how many you've done. I've done plenty
May 31, 2015 | Toro 36" Cut Wide Area Walk Behind Lawn...
Why lawnmower cut off after it start
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward. also check out the kinks below
Lawn Mower Troubleshooting Guide Engine
Small Engine Repair Help
May 01, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
I have a 1987 Toro GTS Self propelled walk behind mower- My question is that it runs fine but but seems to be slippling and can't get out of it's own way
  • Check for belt stretching even if it looks good. Next possibility
Is worn smooth, or oily surfaces on drive wheels. Can you tell if it slips on drive wheel, or those driven. Some Hondas have belt tensioners which can be too loose. See if axle on drive wheel is in a slotted, rather than round whole, meaning you could loosen/retighten while putting pressure on it to lengthen distance to driven wheels.
Apr 01, 2014 | Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
Toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
Aug 18, 2011 | Toro Power Lawn Mower
I have a Toro walk behind self propeled mower. Last summer my sons hit something which made the mower stop running. I was told that I needed to replace somesort of key...? How...? How do I get the top off....
Was it the 'flywheel key' ? Does it yank the rope out of your hand violently when you try to start it?
Take the top shroud off, remove the flywheel nut, washer and screen. Remove the flywheel by threading the nut back onto the crank end to protect the threads and with a brass hammer ( and while lightly prying with a screwdriver from behind the flywheel) and a few good solid taps on the end of the crankshaft the flywheel should free up.
Remove the flywheel and inspect the key. Even .001th off will make the motor run funny or not at all.
Dec 07, 2009 | Toro Lawn Mower With Toro Power Tools
Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
205 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
