Question about Health & Beauty
Life Brand model 5534 Smart Logic, when the cuff is inflating, it gets SO tight, feels like my circulation is being cut off and therefore don't think it is giving me proper reading. Plse advise.
    New Friend:
How do I calibrate the machine
Posted on Jan 24, 2014
Cuff inflates way too much..registers EE error
See page 14, it can also be underinflated which is more likely. It depends whether the EEs are next to each other or on top of each other. The inflated cuff has to cut off the blood supply, and then it measures when the flow starts to come back.
It is a manual inflation model if you are in the right category.
http://omronhealthcare.com/wp-content/uploads/hem-432c.pdf
May 08, 2016 | Omron hem-432c manual arm digital blood...
Cuff doesn't inflate lifesource ua767 bp monitor. How do I reset or fix this? Have brand new batteries.
Inflating a Blood Pressure Cuff - YouTube
? 1:01
www.youtube.com/watch?v=8e6qtnHa8ps
Sep 30, 2008 - Uploaded by expertvillage When you take a blood pressure reading it is important to inflatethe blood pressure cuff until you no longer ...
Sep 24, 2015 | Lifesource Health & Beauty
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
Error 3 is showing on my monitor ... What does it mean ?
On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
I hope this helps.
Jul 08, 2014 | Health & Beauty
Sphygmomanometer
I take it the device is either auto or manual. If it uses batteries, they may be exhausted. Or, there is a valve that may be open. It looks like a shiny metal thing near the bulb. Or that valve might be defective, and it just doesn't shut properly. If that's the case, it should hiss a little bit.
The hose might not be screwed together tightly. There are inexpensive, accurate wrist cuffs for blood-pressure monitoring that work very well. If none of this works, you might pick up one of those.
Jan 20, 2014 | Health & Beauty
Omron- HEM712C- why does the\r\ncuff opens,when trying to take pressure.
It's likely due to either improperly seating the cuff over your arm, or the cuff being sized to small for the circumference of your arm. First make sure that the cuff is set up properly, the "hook" end of the velcro needs to be facing away from your arm. Once you double the cuff back, make sure that it is not so tight as to be cutting off circulation. If this occurs the force of inflation will cause the velcro to separate. It's also possible that the package included to small of a cuff. If so the manufactor has a largercuff here. http://www.omrononlinestore.com/JHI/guid.569520918/~/productID.4509/US/details.html
Mar 13, 2011 | Omron Healthcare Omron Hem-712c Automatic...
The cuff is inflating but is taking a long time to deflate and cutting off the circulation. can this be rectified?
hello
Usually in blood pressure apparatus these type of problems are very common. So do not worry.
Actually when you inflate the cuff the pressure goes into the pipe then unscrewing(mercury bp apparatus) or diflating (digital or manual apparatus) the cuff can release the air. There may be two possibilities that why the your equip is not difflating.
1. either there is a blockage in diflating Knob
2 Or in the pipe
The easiest way is to clean the piping by yourself or take it to the nearest medical appliance store, he will clean it for you.
Good day
Mar 01, 2011 | Timex Health & Beauty
The cuff squeezes my arm too much and it hurts. The reading is way too high everytime. I don't know how to adjust it.
do not inflate the cuff too much. if you know your usual blood pressure, just add about 5-10 mmHg when you inflate it so that you won't hurt yourself. for example, if your BP is usually 130/90, squeeze the cuff to 135-140 only. but if you doubt that your BP is way much higher than that by assessing on what you are feeling, just do not squeeze the cuff further than 200.
Jan 21, 2011 | Life Fitness Ultra Blood Pressure Monitor...
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Health & Beauty Logo
301 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
