Question about Haier HDN655E Dehumidifier
Model HD656E dehumidifier ran well till August 2010 not run since although everything lights up. We have no manual. The temp reads 59 F the current humidity setting constantly turns to LO. Is this an indication the room humidity is too low to run the motor or there a problem?
    Genius:
  • 1,400 Answers
Hello
There should be a button on top for the fan speed,High and low.If your running it in automatic with say a humidity setting of 58 to 60,the fan will run low unless the unit sences say 70 to 80% humidity.
There is a filter in the back you may want to clean it, before you know it it will be hot and humid again.
To answer your question the unit is working fine.You can set the humidity level to its lowest point then try high speed,just for a test.
Posted on Mar 25, 2011
I have Haier HD656e which powers up, all controls work and the fan runs, but no water runs into the bucket. The compressor doesn't appera to come on. Anything simple I can check?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 28, 2011 | Haier HD656E Dehumidifier
I need a manual for my Haier dehumidifier Model HD656E. Can you help?
Here is a link to what should be the Owner's Manual for your unit. If it's not identical, it should be close enough to it, to help you.
http://www.haieramerica.com/en/asset/product/31b6415af4
Hope this helped you. Please let me know. Thanks.
Jun 10, 2011 | Haier HD656E Dehumidifier
I need an owner's manual for my Haier dehumidifier model HD656E. Can you help me?
Here is a link for you to download the manual. http://www.retrevo.com/support/Haier-HD656E-manual/id/951dj390/t/2/
Please rate this post! Thank you!
I have a HD456E that I purchased at Menards about 2 years ago. It's worked fine until a few days ago. It is running but, not a drop of water is in the pan. What do I need to do? I have misplaced my...
Hello friend, I may be of help after all in locating a user/service manual for your hair HD456E dehumidifier.
Check the link below and download the specific manual.
Hope this helps https://haier.encompass.com/shop/model_research_docs/?file=/HAI/om/HD656E.pdf
Even though you'd notice the link reads at the end hd656e.PDF, go ahead and download it. Same manual applies. *smiles*
It is specified on the user manual HD456E
Nov 16, 2017 | Haier HD456 Dehumidifier
I have an Haier HD656E dehumidifier. The past couple of days it has been on, but only the fan is running. I hear the noise as if the evaporation part wants to turn on, but is not. I have the temp. set...
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 15, 2010 | Haier HD656E Dehumidifier
Unit wont run but lights up. It reads low humidity even though its high
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | Haier HD656E Dehumidifier
Haier hd656e, my dehumidifier runs about 30 sec and turns off,
This sounds like a main circuit board problem and is very common with many dehumidifiers... They can be replaced on some units. You can do a search online for the part easily...to see if it is available.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 16, 2010 | Haier HD656E Dehumidifier
Dehumidifier Brand haier HD456E does not pull water and the tank is empty, after 24 hours of running with water on wood floor. Can't find manual or online info for this model.
I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
Apr 12, 2009 | Haier HD656E Dehumidifier
Haier HDN655E Dehumidifier Logo
101 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
