Question about Apple MacBook PC Notebook
I have a RW CD with info on it. I want to erase the current info and burn audio to CD using a Mac
  • 112 Answers
  1. Insert the disc in the optical drive of your computer.
  2. Open Disk Utility, located in Applications/Utilities.
  3. Select the disc in the column on the left and click Erase.
  4. Select Quick Erase if you don't want to overwrite the old contents with zeros.
  5. Click Erase.
Posted on Mar 25, 2011
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
Tip
How to Erase a Burned CD
CD-RW stands for CD re-writeable. This type of disc can be written on or "burned" multiple times. However, in order to burn music or data onto a CD-RW that already has something on it, you must first erase the current contents of the disc. No special software is needed to do this, as you can do it with the Windows Media Player program, which already comes installed on all computers with the Windows operating system. Regular CD-R discs cannot be erased or reused--the discs must be labeled as CD-RW.
Instructions
Step 1.
Click on the "Start" menu button in the lower left-hand corner of the screen. Select "Windows Media Player" from the pop-up menu.
Step 2.
Select the "Library" tab in the main Windows Media Player screen.
Step 3.
Insert the CD-RW that you want to erase in the CD-ROM drive. Close the "AutoPlay" window if it appears.
Step 4.
Right-click the CD-ROM drive in the "Navigation" pane on the left side of Windows Media Player. Select "Erase disc" from the drop-down menu. This will automatically erase the contents of the disc.
on Jul 17, 2010 | Computers & Internet
A friend installed a new Super multi LG Secure Disc player on my computer. But I am not able to play DVD's or make a copy of a DVD program. When I try to copy a DVD the only option I have is to open...
this might be because you have not selected the option to burn an audio dvd or your burning software does not support dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
Jun 08, 2011 | LG SecurDisc 20x Internal Double-Layer DVD...
I don't founr cd 74 mn 650mb, what use the DENON CDR M30 ??
If I understand your question, it can play any kind of music CD but it can only record on CDR-Audio or CDR-Music discs only.
• Only audio CD-R/RW discs can be recorded with this unit. "Use Audio CD" will be displayed when a disc other than one
for use with audio such as a CD-R/RW disc for use with a personal computer or another type of disc is loaded. (See "Discs that Can Be Used with this Unit" on Page 5.)
• CD-R discs can be recorded to only once. The recorded information cannot be erased.
• The recorded information of CD-RW discs can be erased. When this disc has been finalized, erase after the finalization removal operation has been performed. (See "Cancellation of CD-RW disc finalizing" on Page 28.)
• Recording mistakes made with CD-R discs cannot be erased; therefore, it is recommended that a CD-RW disc be used until you are accustomed to the recording operation.
If you desire 74-minute blank disc just Google "cd-r audio 74". The unit will also use 800MB 80-minute CD's.
Jan 31, 2011 | Denon CDR-M30 CD Recorder
My laptop will only burn DVD-RW but i only have DVD R dvds and i was wondering how can i get my latop to burn DVD R dvds?
Hi there!
What is the model of your laptop? Its is actually will depends on your laptop, but here's some infos about it, a DVD-R is a write-once format: once you've burned the data onto that DVD platter, the disk is forever frozen with that information. Add the "W" to that, and you'll find that DVD-RW can be erased or rewritten up to a thousand times. Seems kinda weird, but if you can do so, DVD-RW obviously has significant advantages over DVD-R. DVD-RAM was even more flexible, however, since it let you erase and rewrite sections of an existing DVD, something that you cannot do with DVD-RW.
Moving to the plus side is where things get a bit confusing, because DVD+RW came before DVD+R. The plus formats have the same data storage capacity as the minus formats (4.7GB), but DVD+RW offers faster writing, better internal linking (a technical obscurity you don't have to worry about), and support for drag-and-drop desktop files, which makes it easy to compose the contents of a disk. DVD+R is a write-once format intended to be more compatible with more DVD players, though at this point it seems to be about even with DVD-R, which remains the most compatible computer-burned DVD format.
In your case, since your drive is a DVD-RW, you're effectively limited to DVD-R and DVD-RW format discs. Stay away from any of the "plus" formats, as those won't work with your drive (and being newer, they cost more anyway). As to whether you want to use DVD-R or DVD-RW, that depends on what you want to use them for. DVD-R is a write-once format, just like CD-R, and you can't erase the data once it's written. DVD-RW is rewritable, so you can use it somewhat like a 4.7GB floppy disc, for all intents and purposes. In general, I suggest that you use DVD-R for archival purposes -- stuff that isn't going to change, and DVD-RW for more fluid data. DVD-RW discs are more expensive than DVD-R discs, so that may also influence your decision.
How do you confirm what format your drive works with? One way, if you're on a Mac, is to use the System Profiler application. You'll find this useful utility in Applications -> Utilities. Launch it, then click on the "ATA" item on the list. If you have an internal DVD burner, you'll see something like what I get: "PIONEER DVD-RW DVD-106D". If it's an external DVD drive, you might find it in SCSI, USB or FireWire, depending on how you hook it up.
As far as your second question, your data-burning application definitely has to be aware of the DVD format you want to use (i.e. DVD-R or DVD-RW in your case). For Windows, you can use GEAR for burning CDs, but you'd need to upgrade to GEAR Professional Edition to be able to burn both CDs and DVDs. Toast Titanium does burn DVD-R and DVD-RW so you should be set in that department.
Hope it helps, if you need further, pls contact me.
regards, fossildude
Oct 15, 2010 | Computers & Internet
Ejecting some dvds after about 30 sec.
The Mac can read DVDs, but not all of them: you will see supported DVDs  in the Apple menu - About this mac - More Info - Under "Hardware", select "Disc Burning". You should see the CD/DVD writing capabilities.
For my mac it's
-R, -RW, -R DL, -RW, +R, +R DL, +RW
Jun 29, 2009 | Apple PowerBook G4 17" 1.33GHz Mac...
I don't know how to erase a cd. i try deleting the folders, i am told its read only.
Hi, you can only Erase a CD that is RW. any other cd can't be erased. if its a R cd it can't be erased and those are one time cd's one time write and then it can't be erased and when its full you can't change it, you will need a new disc.
Mar 19, 2009 | Verbatim DataLifePlus Ultra Speed CD-RW...
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
DVD+RW problem
When burning CD/DVD use a lower burning method... as not to rush data to burn and make sure that before burning the let it verify or test the data burned on the CD/DVD... it takes time, but be patient, after all it is your data.
Dec 10, 2007 | LaCie d2 DVD-RW Burner
NEC-3520A Suddenly stop to burn correctly, but reads OK
Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
Jun 11, 2007 | NEC (ND-3520A-KIT-BLU) Burner
Apple MacBook PC Notebook Logo
81 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
