Question about AEG Refrigerators
Hiya i have a S85628SK1 fridge/freezer and its showing EF on both temp readout displays and says temp is high and also temp readjusting but freezer is defrosting
  • 87 Answers
SOURCE: fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Posted on Sep 06, 2007
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
  • 25 Answers
SOURCE: Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Posted on Jul 09, 2008
  • 16 Answers
SOURCE: have a hotpoint rsf60 fridge/freezer,noticed
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Posted on Nov 29, 2008
SOURCE: Lec Elan Fridge Freezer: Freezer
Check freezer door seal
Regards, Barry
Posted on Feb 26, 2009
My refrigerator is not keeping temp and there is a code on the water/ice machine reads S(or 5)y EF. What does this code indicate?
If I'm not mistaken EF error code stands for Evaporator Fan which is the fan motor in the back of the freezer section. That would explain the noise you heard. The fan could possibly be frozen or stuck or the motor actually went bad and needs replaced. Without that fan running you will get very little cooling.
Apr 15, 2015 | Refrigerators
Sub zero 690 control center readout
A picture would be helpful, but there should be two 2 digit numbers. the one on the top should be fridge temp reading somewhere around 34-40, and the bottom one should be freezer temp, reading around -2 to 05.
Feb 25, 2013 | Sub-Zero 690 Side by Side Refrigerator
My refrigerator display shows "Of" how do I get it to normal when I reset the temp for the fridge or freezer the display goes back to "Of"
I just had the same problem with my Samsung. OF means it is in demo mode. On my fridge I had to press "Energy Service" key and "Power Freeze" key simultaneously for at least 3 seconds to bring the fridge out of demo mode. Hope this helps.....
Jan 28, 2013 | Samsung Refrigerators
Psc25pssc ss
If it has auto defrost the temp shown will go really high but only for a short while. It sounds like the defrost timer may be faulty if it is defrosting products
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
On the freezer and fridge temp display there are the codes SY and EF. My manual doesnt give any trouble codes.
There is either something wrong with the fan or the computer. But the only thing you can do is go through the owners manual if you can't correct it with that you will have to call for warranty service. If you go any further then that you will void the warranty.
The short answer is that EF on the Electrolux refrigerator digital display means "evaporator fan." The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Hope helps.
Apr 07, 2011 | Refrigerators
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 12, 2011 | Hotpoint Refrigerators
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
I have a frigidaire sisde by side refrigerator model # FSC23F7TDW. My Temperature control is reading the the freezer & fresh food temp in centigrade. How do I get the Temp display to read in...
Same Guest as above posting this ... By the way, I have a FLSC238DS5 ... I spent 45 minutes on phone w/Frigidaire this afternoon (Phone#: 706-860-4110 Option 1 --> then Option 3). Didn't get anywhere. They say there are 3 solutions that should change it from C to F: 1) In between LED readouts for "Freezer Temp" and "Fresh Food Temp" there is a mode button that is hidden under the plate that you can press w/your finger OR 2) Hold "Fresh Food Temp" Up Arrow Key down, within 5 Seconds press "Freezer Temp" Up Arrow Key 3 times and it should change C to F or vice verse. Didn't work for me so she said 3rd option was to have a service tech come and diagnose. She said there would be a charge. I am not paying to have somebody come here to resolve this issue. That is when I asked her to escalate it to a supervisor which she did. Hopefully, I get a call back & a solution. Stay tuned ...
May 24, 2008 | Refrigerators
Refrigerators Logo
69 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
Ian Jones
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
