How can I tell if a WM48 Zoeller Sump pump is operational. It appears the water level is over the float.
Depending on the sensitivity of the float switch you may find that the float must be completely upside-down for the pump to turn on. The easiest way to check if the pump works is grab the float by hand and hold it in the inverted position - if your pump kicks in and starts pumping you know the pump itself works and you may want to adjust your float (I use tie-straps around the handle and around the float cord to artificially shorten the float). If your pump does not pump water when the float is inverted try shaking the float to see if the inner switch is stuck. Hope that helps.
Posted on May 03, 2011
Zoeller m267-f pump has power going to the motor but will nut run
Does it have a float switch? Does the motor run when you lift the float switch? If not... then the motor's gone.
Jul 23, 2014 | Zoeller Sump Pump with 25 foot cord 2" 1/2...
Tip
Fixing a Zoeller M53 Sump Pump that won't turn on. Turns on by tapping or...
Just wanted to share my fix story. A couple of years ago I had a problem with my zoeller sump pump to turning on but it would if I ever so lightly tapped it or the discharge pipe. Naturally I suspected the switch and replaced it with the same results. I ended up zip tying a piece of foam to the float and bingo! This worked great for awhile until the foam loosened and got stuck. So back to the drawing board. I noticed on a parts list that zoeller recommends changing the float arm when replacing the switch. Put in a new float arm and it works great! No foam needed. I never thought to replace it in the first place because the old one moved fine but when compared to the new arm the new one is much smoother. I was able to remove the old arm with channel lock pliers and the new piece is press fit with some loctite #609 that came with it. Hope this helps!
on Apr 04, 2012 | Zoeller M53 Mighty Mate Iron Body, Poly...
Zoeller Pump M57
The only "easy fix" may be a stuck float switch. First make sure the outlet where the pump is plugged in works. Plug something into the outlet such as a work light to confirm the outlet is live. The float switch may be stuck in the OFF position. Giggle the float arm up and down several times to see if the pump comes on.> You can spry wd40 into the switch where the arm enters. If this does not work, the pump probably needs servicing.
Apr 07, 2014 | Zoeller Sump Pump, 3/10 HP - M57
My Zoeller M57 pump has stopped working. It won't even turn on...is there a reset switch or some other easy fix for this?
These Zoeller pumps are very good quality> I suspect that the float switch is not working, which is why the pump is not turning on.You may try giggling the float arm that is attached to the switch. You can also try spraying some WD 40 into the switch where the arm enters. Zoeller does have replacement parts for their pumps. Review their website for your pump parts.
50 Series Zoeller Pump Company
Fixed! Zoeller M53 won't turn on. Will turn on with a slight tap.
I had the same problem of pump not turning on unless I tapped the pipe to create a vibration. I took the float off and cleaned the grime / buildup. The buildup changed the buoyancy of the float (made it heavier) such that it did not float high enough to trigger the switch. Once cleaned, the float floats much higher above the water line and triggers the switch.
Where can i buy a replace float road for a m98-b zoeller water pump
zoeller is a pump normally found only at plumbing and heating supply houses. they should carry or can order thge part for you
Jan 04, 2010 | Zoeller M53 Mighty Mate Iron Body, Poly...
Sump pump float adjustment
This really depends entirely on you. the higher the water level the less frequently it will run. most motors use more power to start than they do to run so starting less should save you money.
Nov 16, 2009 | Zoeller 10-0034 Switch-Mate Pump Float...
Pump won't shut off. Float is free and moving, but doesn't switch unit off when in down position. Is there a fix or is it time for new pump?
Can you replace the switch? If not, you can wire in a new generic float switch for far less than purchasing a new pump. A decent hardware or electrical supply house should have a float switch and they should be able to help you wire it or you can Google float switch installation to get an idea of how to do it yourself (it is not too complicated).
i hope this helps
matthew
Nov 02, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
Replacing float switch on water ace r3s pump
I have been in this business for a ong time 34 years by the time ou take the pump apart and find the right peices it would be cheaper to buy a new pump, suggest zoeller submersable pump,,
Mar 17, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Water backs up in the floor drain during heavy downpour even thou
the sump pump shold not be run into the sanitary sewer, but if your floor drain is hooked to a sump pump pit and it doesn';t pump the water before it gets to the drain tile it could come up in the drain,, to solve the problem get a pump that the float is lower in the pit,, suggestion zoeller cast iron submersable pump cost about 100 less the install price, great low profile pump, it keeps less waterin the sump pump pit so there is less mosture
Mar 11, 2009 | Invacare Supply Group Invacare Top End...
Heating & Cooling Logo
447 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
