Question about Whirlpool Washing Machines
Washer wont stop running water over flou - Whirlpool Washing Machines
    Sergeant:
    Champion:
  • 202 Answers
You have a bad presure sensor switch and a presure hose ....
Posted on Mar 25, 2011
Water wont stop running in washer
call a repairman after you unplug it and turn off the water lines behind the washer
Jul 21, 2015 | Washing Machines
Water wont cut off
Does the water run if you push the timer dial in to stop the cycle or does it run even if you unplug the washer?
Dec 31, 2011 | Whirlpool LSR7333 Top Load Washer
We start the washer and it runs for about 20 minutes. Then it stops and the letters nf come on the control panel and it wont run. Can you please what that means?
According to the user manual for your washer (which is available here, http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202206687.pdf), "nF" means the washer is unable to fill with water. Make sure your water supply lines are free of obstructions or kinks, and also that the water valves are turned on all the way.
Jan 29, 2011 | Maytag Neptune MAH6500A Front Load Washer
I have LGwm2016cw.. i get no error code. the washer wont stop adding water and it wont drain the water. any ideas
A small tube running up the side of the tub carries air prussure to tell the machine to stop filling.Mos likely the hose has disconnected.
Mar 21, 2010 | LG WM-2277HW Front Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
My washer wont stop filling with water it will run over into floor it will agitate but water keeps running . it is a whirlpoot top loading.
you nead to check the plastic hose from the water leval switch to thbe outer tub.if line is good than you have a bad water leval switch.
Oct 29, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer water wont stop running and switch to wash. It overflowed
sounds like a bad water valve. Try disconnecting for a few minutes. If problem continues, the solenoid on the water valve is staying open which means the circuit is not opening. Replace valve.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Whirpool duet washer
you have something in the water valve on the washer replace the water valve
May 07, 2008 | Whirlpool GEW9200L Electric Dryer
Washing Machines Logo
54 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
