Question about Omron HEM-711 IntelliSense Automatic Blood Pressure Monitor
The systolic number is much higher than the number on my doctor's device.
    Brigadier General:
  • 4,736 Answers
Your BP monitor may need recalibrating. In which case, the manufacturer can do that for you. Also, remember, when you take your BP at home, if you had just eaten, smoked a cigarette, drank a cup of coffee, etc. It will affect your blood pressure rather quickly.
Hope this helped you. If so, please take a moment, to kindly rate my response to you. Thanks and have good day!
Posted on Mar 25, 2011
What is normal systole range
A normal systolic blood pressure is 120 or below. A systolic blood pressure of 120-139 means you have normal blood pressure that is higher than ideal, or borderline high blood pressure.
https://www.webmd.boots.com/hypertension-high-blood-pressure/guide/diastolic-systolic
Nov 07, 2017 | Health & Beauty
What is the ideal blood pressure for a male at the age of 75
Any adult person should ideally have a B/P around 120/78. HOWEVER, it can be common for an older person to be as high as 100 plus their age. (ie: 175/x)
In EMS, high B/P begins about 140 Systolic. (Systolic is the upper number. Diastolic is the lower number.)
Most B/P medications work mostly to control the Systolic, but the
lower number is also more important than most realize. When the Diastolic B/P gets over 90, the body may not be getting "perfusion" efficiently. Perfusion is where the body exchanges wastes for
nutrients in the blood by means of the capillaries. In other words,
the body is just not doing a good job of 'feeding itself' and getting rid of the toxins in the blood.
Watch your blood pressure, and see a doctor if it is running high.
You should check with your doctor at least twice each year.
Apr 19, 2017 | The Health & Beauty
Causes high systolic blood pressure
Isolated systolic hypertension can be caused by underlying conditions such as artery stiffness, heart valve problems or an overactive thyroid (hyperthyroidism). For years, doctors focused primarily on diastolic blood pressure. The recommended goal for systolic pressure for younger people is less than 140 mm Hg.
Apr 05, 2017 | Health & Beauty
What is normal blood pressure for men
Blood pressure fluctiates throughout the day. So tak toma doctor if you are worried
Mar 26, 2017 | Health & Beauty
My blood pressure is 110/95 and my heart rate is 124/bpm. I am pregnant what does that mean?
110/95 Blood Pressure
Is 110/95 Good Blood Pressure or High Blood Pressure?
There are two parts or two separate numbers referred to as blood pressure: Systolic/Diastolic. If the blood pressure is 110/95 (110 over 95), it means that the systolic pressure is 110 and the diastolic pressure is 95.
110/95 blood pressure can also be read as 110/95 mm Hg, or 110/95 millimeters of mercury. The 110 mm Hg Systolic refers to the pressure in the arteries when the heart beats, and the 95 mm Hg Diastolic is the pressure in the arteries between heartbeats.
When determining if 110/95 is a good blood pressure, we looked at the American Heart Association's blood pressure chart.
Blood Pressure Systolic Diastolic Normal Less than 120 Less than 80 Prehypertension 120 - 139 80 - 89 High Blood Pressure
(Hypertension) Stage 1 140 - 159 90 - 99 High Blood Pressure
(Hypertension) Stage 2 160 or higher 100 or higher Hypertensive Crisis
(Emergency care needed) Higher than 180 Higher than 110
For 110/95 to be good, both numbers must fit into the "normal" category above. Otherwise, it will fall into other categories of High Blood Pressure.
Systolic reading of 110 is in the Normal range.
Diastolic reading of 95 is in High Blood Pressure (Hypertension) Stage 1 range.
Therefore, 110/95 is High Blood Pressure (Hypertension Stage 1).
Aug 05, 2014 | Veridian Healthcare 01-539 SmartHeart Arm...
Manual for cvs model BP3MU1-1E
fakonobea, it means pulse / diastolic / systolic. Pulse is how many times your heart is beating per minute. Systolic is the pressure when your heart is contacting; it is the top number. Diastolic is the bottom number and it is the pressure when your heart is at rest. Normal pressure is 120 systolic and 80 diastolic, or 120/80.
If you have further questions, I suggest talking to your doctor or health care professional, they will be happy to tell you.
Aug 18, 2012 | Health & Beauty
Systolic rate is higher than when I was in the Doctor's office the other day. I believe it needs to be re-calibrated. Where can I go to have it re-calibrated.
Jean, recalibration has to be done by the manufacturer of the monitor. They usually offer this at no charge, other than the shipping cost.
Hope this helps you.
Apr 27, 2011 | Omron HEM-711 IntelliSense Automatic Blood...
Sunbeam7650 Don't know how to properly set the Pressure Selector
The switch tells the machine how high to pressurize the cuff when it starts. It needs to somewhat higher than your normal systolic pressure (mm Hg). (So if your systolic (top number) bp is regularly between 100 and 130, set the switch to 160.) Similarly if your systolic pressure is regularly above 130 but below 170, set it to 200)
I hope this helps.
Jul 19, 2010 | Sunbeam Digital Blood Pressure Monitor
Systolic numbers do not form completely
Try changing the batteries if that doesn't work I would buy a new machine. If you have high blood pressure a lot of health care plans will buy you a monitor. Ask your health plan or doctor for more info.
Nov 11, 2008 | One Touch A & D One-touch Blood Pressure...
Omron HEM-711 IntelliSense Automatic Blood Pressure Monitor Logo
289 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
